Ansys 产品
Ansys 产品
繞線式轉子同步馬達等效電路提取Wound Rotor Synchronous Motor ECE model
    • Cathy Lee
      對於WRSM的ECE模型不確定轉子的繞組應該怎麼設置,我將場繞組也設置外部電路,並且在ECR3和ECER外多加了ECEW model,但是FEA分析結果轉速非常得奇怪明顯不對,不知道應該怎麼修改了
    • Navya Chode
      Translation:
      For the ECE model of WRSM, I am not sure how to set the windings of the rotor, so I set the field windings with external circuits, and add ECEW models in addition to ECR3 and ECER, but the FEA analysis results are very strange and obviously wrong, and I don't know how to modify them
    • HDLI
      Hello Cathy,
             It seems to me your setting is correct, and field coil is for ECEW. 3 phase coils are to use ECE3.
             Why do you think the FEA results are not correct? Thanks.
      HDLI
    • Cathy Lee
      Following are the results plots of WRSM FEA.
    • HDLI
      Hello Cathy,
           Could you show the Simplorer schematics? Could you run open circuit first? It seems to me there is zero torque.
      HDLI
Viewing 4 reply threads
  • 您必须登录才能回复此主题。
