Random Vibration: The result data for SPSD is not contained in the result file
TAGGED: #Modal_Analysis, ansys-apdl, ansys-workbench, apdl, equivalent-stress, error, modal, psd, random-vibration, results
October 3, 2024 at 4:00 pm
AR
SubscriberHello,
I have a model Static -> Modal -> Random vibration in Workbench. It is a large model, so I am expanding only the modes whose ratio of effective mass to total mass is greater than 1e-3 with the following code:
mxpand,none
SOLVE
FINISH
/SOLU
antype,modal,restart
mxpand,all,,,,1e-3,,EFFM
modseloption,,,,no,no,no
SOLVEI have the "Store modal results" set to "For future Analysis". However, when finishing the PSD, I get the following error:
The result data for spsd is not contained in the result file.I have used this same method with a harmonic and it worked fine.
What could be happening? How can I fix it but keep the part where I select what I want to expand?
October 5, 2024 at 3:06 pm
dlooman
Ansys EmployeeYou didn't request stresses in the modal. It should have been mxpand,all,,,YES,1e-3,,EFFM
October 10, 2024 at 7:58 am
AR
SubscriberThank you !
6790
1332
1152
