May 4, 2023 at 5:28 am
Ahmad Alfakeer
SubscriberHello AllÂ
i have one qustion about PDS data that enter to ansys ? how we can get PDS data to enntering it to randon vibration analysis and i can to take vibration from strctures by accelermeter sensor & data collector , can i used this data in PDS Curve or not ?Â
May 4, 2023 at 11:58 am
Ashish Khemka
Forum ModeratorHi Ahmad,
Input PSD curves are often provided based on engineering specifications or criteria that must be met. You might need to refer design hand books or data from test engineers. Data loggers which record and process the data from accelerometers provide the time history or frequency data and I am not sure if you can use the same directly for PSD input.
Please see if the following course is of any help to you: Random Vibration Analysis in Ansys Mechanical | Ansys Courses
Ashish Khemka
May 5, 2023 at 5:52 am
Ahmad Alfakeer
Subscriberthank you for your replyÂ
- The topic ‘Random vibration analysis of structure -PDS’ is closed to new replies.
5809
