October 21, 2023 at 7:18 am
louiee1907
SubscriberHi,
Thanks to harmonic analysis I calculated FRF, I used 9800 mm/s^2 as acceleration data. Vibration generator is g^2/Hz in nCode DesignLife, and my PSD datas changes from 0 Hz to 2000 Hz as g^2/Hz. Since I used mm/s^2 in harmonic analysis, must I convert g^2/Hz to mm/s^2/Hz in nCode?Â
Are they same unit both in harmonic analysis and in nCode DesignLife?
October 26, 2023 at 12:13 pm
ashish.khemka
Forum ModeratorHi, Please see if the following link helps: /forum/forums/topic/response-spectrum-vs-random-vibration/ Regards, Ashish Khemka
- The topic ‘Random PSD Analysis’ is closed to new replies.
