July 31, 2020 at 5:21 pm
prajput
Ansys EmployeeHello, what are RFIDs?
Thanks in advance.
July 31, 2020 at 5:22 pm
CB
Ansys EmployeeHi - RFID is an acronym that stands for “Radio-Frequency IDentification”. RFID is a very widely used technology and still rapidly developing. RFID uses include tracking equipment, goods, animals, etc. There is a large need to automatically enter information identifying an object with an automated ID. Bar codes and magnetic stripes are examples of RFIDS being used today.
prajput
Ansys EmployeeHow does these RFIDs works?
rtk
Ansys EmployeeHello @prajput ,
RFID uses the methods of Automatic Identification and Data Capture (AIDC), which automatically identify objects, collect data about them, and enter those data directly into computer systems with little or no human intervention. It uses electromagnetic waves to accomplish this.
July 31, 2020 at 5:23 pm
prajput
Ansys EmployeeAre there many types of such RFID Tags? Any insight on that would be helpful.
CB
Ansys EmployeeHi @prajput , Yes, RFID tags can be of any shapes and sizes. Mainly they are classified into Passive and Active RFID tags. Passive tags are less expensive and are widely used ones. But it must be powered up by the RFID reader for transmitting data. Whereas, RFID tags have onboard power supply, like an in-built battery, for data transmission.
Viewing 5 reply threads
- The topic ‘Radio Frequency Identification Tags’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1318
1156
