December 9, 2024 at 12:49 pm
thomas.fellinger
SubscriberHello,
I get an unknow error doing a thermal simulation by radiation:
A plate with a certain temperature is surrounded by a box. I want to simulate to investigate the temperature over time.
If the box has a mesh size of 20mm and the plate 5mm than it works. Changing the mesh size only of the plate to 1mm, an unknow error occurs, see both solver output files below.
I also tried to reduce the mesh size of the box - no positive result.Someone my have an idea why this happens (solver setting, boundares, mesh,...)?
Case 1: Error 1mm mesh size of the plate, other bodies 20mm
Solver Output
 Ansys Mechanical Enterprise Academic Research   Â
 |  W E L C O M E  T O  T H E  A N S Y S (R) P R O G R A M    |
 *        ANSYS MAPDL 2022 R2         LEGAL NOTICES         *
 * Copyright 1971-2022 Ansys, Inc. All rights reserved.      *
 * Unauthorized use, distribution or duplication is           *
 * prohibited.                                                *
 * Ansys is a registered trademark of Ansys, Inc. or its      *
 * subsidiaries in the United States or other countries.      *
 * See the Ansys, Inc. online documentation or the Ansys, Inc. *
 * documentation CD or online help for the complete Legal     *
 * Notice.                                                    *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION      *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY     *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.   *
 * The software products and documentation are furnished by   *
 * Ansys, Inc. or its subsidiaries under a software license   *
 * agreement that contains provisions concerning              *
 * non-disclosure, copying, length and nature of use,         *
 * compliance with exporting laws, warranties, disclaimers,   *
 * limitations of liability, and remedies, and other          *
 * provisions. The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance *
 * with the terms and conditions of that software license     *
 * agreement.                                                 *
 * Ansys, Inc. is a UL registered                             *
 * ISO 9001:2015 company.                                     *
 * This product is subject to U.S. laws governing export and  *
 * re-export.                                                 *
 * For U.S. Government users, except as specifically granted  *
 * by the Ansys, Inc. software license agreement, the use,    *
 * duplication, or disclosure by the United States Government *
 * is subject to restrictions stated in the Ansys, Inc.       *
 * software license agreement and FAR 12.212 (for non-DOD     *
 * licenses).                                                 *
 2022 R2
 Point Releases and Patches installed: Â
 ANSYS, Inc. License Manager 2022 R2
 Discovery 2022 R2 Â
 SpaceClaim 2022 R2Â
 Ansys Sherlock 2022 R2Â
 Autodyn 2022 R2
 LS-DYNA 2022 R2
 CFD-Post only 2022 R2 Â
 CFX (includes CFD-Post) 2022 R2
 Chemkin 2022 R2
 FENSAP-ICE 2022 R2Â
 Fluent (includes CFD-Post) 2022 R2Â
 Polyflow (includes CFD-Post) 2022 R2
 Forte (includes EnSight) 2022 R2
 TurboGrid 2022 R2 Â
 ICEM CFD 2022 R2
 Aqwa 2022 R2
 Speos 2022 R2 Â
 Speos HPC 2022 R2 Â
 optiSLang 2022 R2 Â
 Additive 2022 R2
 Customization Files for User Programmable Features 2022 R2Â
 Mechanical Products 2022 R2
 Remote Solve Manager Standalone Services 2022 R2
 Ansys Sound - SAS 2022 R2 Â
 Viewer 2022 R2Â
 ACIS Geometry Interface 2022 R2
 AutoCAD Geometry Interface 2022 R2Â
 Catia, Version 4 Geometry Interface 2022 R2
 Catia, Version 5 Geometry Interface 2022 R2
 Catia, Version 6 Geometry Interface 2022 R2
 Creo Elements/Direct Modeling Geometry Interface 2022 R2
 Creo Parametric Geometry Interface 2022 R2Â
 Inventor Geometry Interface 2022 R2
 JTOpen Geometry Interface 2022 R2 Â
 NX Geometry Interface 2022 R2 Â
 Parasolid Geometry Interface 2022 R2 Â
 Solid Edge Geometry Interface 2022 R2 Â
 SOLIDWORKS Geometry Interface 2022 R2 Â
         ***** MAPDL COMMAND LINE ARGUMENTS *****
 BATCH MODE REQUESTED (-b)   = NOLIST
 INPUT FILE COPY MODE (-c)   = COPY
 DISTRIBUTED MEMORY PARALLEL REQUESTED
     15 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS (FORCED)
   TOTAL OF   15 CORES REQUESTED
 INPUT FILE NAME             = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\ScrA868\dummy.dat
 OUTPUT FILE NAME            = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\ScrA868\solve.out
 START-UP FILE MODE          = NOREAD
 STOP FILE MODE              = NOREAD
 GPU ACCELERATOR OPTION REQUESTED
    1 GPU ACCELERATOR DEVICES REQUESTED
 RELEASE= 2022 R2             BUILD= 22.2     UP20220516  VERSION=WINDOWS x64
 CURRENT JOBNAME=file0 13:36:36 DEC 07, 2024 CP=     0.219
 PARAMETER _DS_PROGRESS =    999.0000000  Â
 /INPUT FILE= ds.dat LINE=      0
 *** NOTE ***                           CP =      3.438  TIME= 13:36:41
 The /CONFIG,NOELDB command is not valid in a distributed memory       Â
 parallel solution. Command is ignored.                               Â
 *GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 13.6113889  Â
 TITLE=
 Test_Radiation--Transient Thermal (B5)                                      Â
 ACT Extensions:
     LSDYNA, 2022.2
     5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
 /COM,    ANSYSMotion, 2022.2
     20180725-3f81-49eb-9f31-41364844c769, wbex
 SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
 TYPE=STRI DIMENSIONS=     248       1       1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\ScrA868\
 SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = E:\Test_Beam_1.63MW_Sig5mm\Test_Radiation_files\dp0\SYS-30\MECH\
 SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = E:\Test_Beam_1.63MW_Sig5mm\Test_Radiation_files\user_files\
 --- Data in consistent NMM units. See Solving Units in the help system for more
 MPA UNITS SPECIFIED FOR INTERNAL  Â
 LENGTH     = MILLIMETERS (mm)
 MASS       = TONNE (Mg)
 TIME       = SECONDS (sec)
 TEMPERATURE = CELSIUS (C)
 TOFFSET    = 273.0
 FORCE      = NEWTON (N)
 HEAT       = MILLIJOULES (mJ)
 INPUT UNITS ARE ALSO SET TO MPA
 *** MAPDL - ENGINEERING ANALYSIS SYSTEM RELEASE 2022 R2         22.2    ***
 00000000 VERSION=WINDOWS x64  13:36:41 DEC 07, 2024 CP=     3.438
         ***** MAPDL ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "cover1" ***********
 *********** Elements for Body 2 "cover2" ***********
 *********** Elements for Body 3 "cover3" ***********
 *********** Elements for Body 4 "cover4" ***********
 *********** Elements for Body 5 "End1" ***********
 *********** Elements for Body 6 "End2" ***********
 *********** Elements for Body 7 "SYS-29\400x400x5\Solid" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Send Materials ***********
 *********** Create Contact "Contact Region" ***********
            Real Constant Set For Above Contact Is 9 & 8
 *********** Create Contact "Contact Region 2" ***********
            Real Constant Set For Above Contact Is 11 & 10
 *********** Create Contact "Contact Region 3" ***********
            Real Constant Set For Above Contact Is 13 & 12
 *********** Create Contact "Contact Region 4" ***********
            Real Constant Set For Above Contact Is 15 & 14
 *********** Send Named Selection as Node Component ***********
 *********** Send Named Selection as Element Component ***********
 *********** Define Temperature Constraint ***********
 *********** Create "ToSurface(Closed)" Radiation ***********
 ***************** Define Uniform Initial temperature ***************
 ***** ROUTINE COMPLETED ***** CP =       33.188
 --- Number of total nodes = 3895043
 --- Number of contact elements = 960
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 828438
 --- Number of condensed parts = 0
 --- Number of total elements = 829398
 *GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 13.6130556  Â
 *************************   SOLUTION      ********************************
 ***** MAPDL SOLUTION ROUTINE *****
 PERFORM A TRANSIENT ANALYSIS
 THIS WILL BE A NEW ANALYSIS
 STEP BOUNDARY CONDITION KEY= 1
 USE PRECONDITIONED CONJUGATE GRADIENT SOLVER
 CONVERGENCE TOLERANCE = 1.00000E-08
 MAXIMUM ITERATION    = NumNode*DofPerNode* 1.0000  Â
 CONTACT INFORMATION PRINTOUT LEVEL      1
 DO NOT SAVE ANY RESTART FILES AT ALL
 DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
 Use Full Nonlinear Thermal Transient Solution
 NLHIST: ADDED NODAL RESULTS HISTORY FOR:
      NAME = MAX_TEMP                      Â
 ITEM/COMP = TEMPMAX
      NODE =        0
      NAME = MIN_TEMP                      Â
 ITEM/COMP = TEMPMIN
      NODE =        0
 ********* Initial Time Increment Check And Fourier Modulus *********
 Specified Initial Time Increment: 0.05
 Estimated Increment Needed, le*le/alpha, Body 1: 13.957
 Estimated Increment Needed, le*le/alpha, Body 2: 13.957
 Estimated Increment Needed, le*le/alpha, Body 3: 13.957
 Estimated Increment Needed, le*le/alpha, Body 4: 13.957
 Estimated Increment Needed, le*le/alpha, Body 5: 9.39451
 Estimated Increment Needed, le*le/alpha, Body 6: 9.39453
 Estimated Increment Needed, le*le/alpha, Body 7: 0.0563124
 ******************* SOLVE FOR LS 1 OF 1 ****************
 SPECIFIED CONSTRAINT TEMP FOR PICKED NODES
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI939
 Memory resident data base increased from     2048 MB to     4096 MB.
 REAL= 20.0000000      IMAG= 0.00000000  Â
 SELECT     COMPONENT _CM617        Â
 SELECT     ALL ELEMENTS HAVING ANY NODE IN NODAL SET.
    324788 ELEMENTS (OF    829398 DEFINED) SELECTED FROM
  984002 SELECTED NODES BY ESLN COMMAND.
 GENERATE SURFACE LOAD RDSF ON SURFACE DEFINED BY ALL SELECTED NODES
 EMISSIVITY =  1.00          ENCLOSURE NUMBER =       1.
 NUMBER OF RDSF ELEMENT FACE LOADS STORED =    328000
 ALL SELECT  FOR ITEM=NODE COMPONENT=  Â
 IN RANGE        1 TO   3895043 STEP         1
   3895043 NODES (OF   3895043 DEFINED) SELECTED BY NSEL COMMAND.
 ENCLOSURE= 1 VIEWFACTOR SCALE METHOD = 1
              ITERATIONS = 100
              TOLERANCE = 1.000000047E-03
 SELECT     COMPONENT _CM676        Â
     29398 ELEMENTS (OF    829398 DEFINED) SELECTED FROM
   84844 SELECTED NODES BY ESLN COMMAND.
 EMISSIVITY = 0.500          ENCLOSURE NUMBER =       1.
 NUMBER OF RDSF ELEMENT FACE LOADS STORED =     27966
 ALL SELECT  FOR ITEM=ELEM COMPONENT=  Â
 IN RANGE        1 TO   1215626 STEP         1
    829398 ELEMENTS (OF    829398 DEFINED) SELECTED BY ESEL COMMAND.
 PRINTOUT RESUMED BY /GOP
 DO NOT USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE      2 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
  USE     2 SUBSTEPS AS A MAXIMUM
  USE     2 SUBSTEPS AS A MINIMUM
 TIME= 0.10000  Â
 INCLUDE TRANSIENT EFFECTS FOR ALL DEGREES OF FREEDOM THIS LOAD STEP
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
  FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE FFLU ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE MISC ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 CONVERGENCE ON HEAT BASED ON THE NORM OF THE N-R LOAD
  WITH A TOLERANCE OF 0.1000E-03 AND A MINIMUM REFERENCE VALUE OF 0.1000E-02
  USING THE L2 NORM (CHECK THE SRSS VALUE)
 UNDER RELAXATION FOR RADIATION FLUX=  0.10000
 TOLERENCE FOR RADIOSITY FLUX=  0.00001
 USING JACOBI ITERATIVE SOLVER FOR RADIOSITY SOLUTION
 FOR 3D ENCLOSURES.
 USING GSEIDEL ITERATIVE SOLVER FOR RADIOSITY SOLUTION
 FOR 2D ENCLOSURES.
 MAXIMUM NUMBER OF ITERATIONS= 1000
 TOLERENCE FOR ITERATIVE SOLVER=  0.00010
 RELAXATION FOR ITERATIVE SOLVER=  0.10000
 HEMICUBE RESOLUTION= 100
 MIN NORMALIZED DIST BEFORE AUTO SUBDIVIDE= 1.000000000E-09
BEFORE SYMMETRIZATION:
NUMBER OF RADIATION NODES CREATED =Â Â Â Â 328002
NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â Â 328000
AFTER SYMMETRIZATION:
FULL NUMBER OF RADIATION NODES CREATED =Â Â Â Â 328002
FULL NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â 328000
 IN RANGE        1 TO   4223045 STEP         1
   4223045 NODES (OF   4223045 DEFINED) SELECTED BY NSEL COMMAND.
 IN RANGE        1 TO   1543626 STEP         1
   1157398 ELEMENTS (OF   1157398 DEFINED) SELECTED BY ESEL COMMAND.
     29398 ELEMENTS (OF   1157398 DEFINED) SELECTED FROM
NUMBER OF RADIATION NODES CREATED =Â Â Â Â Â 28440
NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â Â Â 27966
FULL NUMBER OF RADIATION NODES CREATED =Â Â Â Â Â 28440
FULL NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â Â 27966
 IN RANGE        1 TO   4251485 STEP         1
   4251485 NODES (OF   4251485 DEFINED) SELECTED BY NSEL COMMAND.
 IN RANGE        1 TO   1571592 STEP         1
   1185364 ELEMENTS (OF   1185364 DEFINED) SELECTED BY ESEL COMMAND.
 *GET ANSINTER_ FROM ACTI ITEM=INT       VALUE= 0.00000000  Â
 *IF ANSINTER_                        ( =  0.00000    ) NEÂ
     0                                ( =  0.00000    ) THEN  Â
 *ENDIF
 *** NOTE ***                           CP =     67.344  TIME= 13:36:52
 The automatic domain decomposition logic has selected the MESH domain Â
 decomposition method with 15 processes per solution.                  Â
 ***** MAPDL SOLVE   COMMAND *****
 CALCULATING VIEW FACTORS USING HEMICUBE METHOD
 RETRIEVED   1 ENCLOSURES.
 TOTAL OF  355966 DEFINED ELEMENT FACES.
 # ENCLOSURE =    1 # SURFACES =355966 # NODES =356442
               V I E W F A C T O R   S M O O T H I N G
   Smoothing of viewfactor matrix...
     Max iterations = 100
     Tolerance     = 0.001
     row sum total should be                  = 355966.0000
     row sum total before forcing symmetry    = 355965.9605
     row sum total after forcing symmetry     = 355965.9605
     row sum total after smoothing            = 355966.0025
     Raw rowsum error min                     = -5.0902e-05
     Raw rowsum error max                     = 8.3447e-07
     Raw rowsum error mean                    = -1.1107e-07 +/- 4.1666e-07
     Symmetric rowsum error min               = -5.0902e-05
     Symmetric rowsum error max               = 8.3447e-07
     Symmetric rowsum error mean              = -1.1107e-07 +/- 6.2869e-08
     Smoothed rowsum error min                = -3.5763e-07
     Smoothed rowsum error max                = 5.9605e-07
     Smoothed rowsum error mean               = 6.9275e-09 +/- 1.4241e-09
     number of iterations to smooth           = 1
       E N D   O F   V I E W F A C T O R   S M O O T H I N G
TIME OF CALCULATION FOR THIS ENCLOSURE =Â Â Â 1659.38Â Â Â
 CHECKING VIEW FACTOR SUM
 VIEW FACTOR CALCULATION COMPLETE
 WRITING VIEW FACTORS TO FILE file0.vf        Â
 VIEW FACTORS WERE WRITTEN TO FILE file0.vf        Â
 *** WARNING ***                        CP =   2502.359  TIME= 15:15:12
 Some radiation enclosures have viewfactor scaling. Use VFSM,STAT     Â
 command to check the status. Also note that scaling is ignored if theÂ
 viewfactor sum is <= 0.0.                                             Â
 *** WARNING ***                        CP =   2504.047  TIME= 15:15:12
 Element shape checking is currently inactive. Issue SHPP,ON or       Â
 SHPP,WARN to reactivate, if desired.                                  Â
 *** NOTE ***                           CP =   2512.906  TIME= 15:15:15
 The model data was checked and warning messages were found.           Â
 Please review output or errors file (                                Â
 E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\ScrA868\file0.err ) for    Â
 these warning messages.                                               Â
 00000000 VERSION=WINDOWS x64  15:15:15 DEC 07, 2024 CP=  2513.234
                      S O L U T I O N  O P T I O N S
  PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D                Â
  DEGREES OF FREEDOM. . . . . . TEMP
  ANALYSIS TYPE . . . . . . . . . . . . . . . . .TRANSIENT          Â
     SOLUTION METHOD. . . . . . . . . . . . . . .FULL               Â
  OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15  Â
  EQUATION SOLVER OPTION. . . . . . . . . . . . .PCG              Â
     TOLERANCE. . . . . . . . . . . . . . . . . . 1.00000E-08
  GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRICÂ
 *** NOTE ***                           CP =   2513.766  TIME= 15:15:15
 This nonlinear analysis defaults to using the full Newton-Raphson     Â
 solution procedure. This can be modified using the NROPT command.    Â
 *** NOTE ***                           CP =   2513.766  TIME= 15:15:16
 The conditions for direct assembly have been met. No .emat or .erot  Â
 files will be produced.                                               Â
 *** NOTE ***                           CP =   2520.984  TIME= 15:15:17
 Symmetric Deformable- deformable contact pair identified by real      Â
 constant set 8 and contact element type 8 has been set up. The       Â
 companion pair has real constant set ID 9. Both pairs should have theÂ
 same behavior.                                                        Â
 ANSYS will keep the current pair and deactivate its companion pair,   Â
 resulting in asymmetric contact.                                      Â
 Pure thermal contact is activated.
 The emissivity is defined through the material property.
 Thermal convection coefficient, environment temperature, and
 heat flux are defined using the SFE command.
 Target temperature is used for convection/radiation calculation
 for near field contact.
 Small sliding logic is assumed
 Contact detection at: Gauss integration point
 Average contact surface length               13.216  Â
 Average contact pair depth                   14.814  Â
 Average target surface length                14.984  Â
 Default pinball region factor PINB          0.25000  Â
 The resulting pinball region                 3.7036  Â
 Initial penetration/gap is excluded.
 Bonded contact (always) is defined.
 Thermal contact conductance coef. TCC        255.64  Â
 Heat radiation is excluded.
 *** NOTE ***                           CP =   2521.172  TIME= 15:15:17
 Max. Initial penetration 1.704990738E-05 was detected between contactÂ
 element 1214749 and target element 1214870.                           Â
 You may move entire target surface by : x= 1.685318E-05, y=           Â
 2.582569568E-06, z= 4.680688417E-19,to reduce initial penetration.    Â
 constant set 9 and contact element type 8 has been set up. The       Â
 companion pair has real constant set ID 8. Both pairs should have theÂ
 same behavior.                                                        Â
 ANSYS will deactivate the current pair and keep its companion pair,   Â
 Average contact surface length               13.295  Â
 Average contact pair depth                   22.753  Â
 The resulting pinball region                 5.6884  Â
 Max. Initial penetration 1.705060237E-05 was detected between contactÂ
 element 1214809 and target element 1214690.                           Â
 constant set 10 and contact element type 10 has been set up. The     Â
 companion pair has real constant set ID 11. Both pairs should have   Â
 the same behavior.                                                    Â
 Max. Initial penetration 1.703900632E-05 was detected between contactÂ
 element 1215012 and target element 1215134.                           Â
 You may move entire target surface by : x= 7.33329464E-06, y=         Â
 -1.538019916E-05, z= 8.119307397E-20,to reduce initial penetration.   Â
 constant set 11 and contact element type 10 has been set up. The     Â
 companion pair has real constant set ID 10. Both pairs should have   Â
 Average contact surface length               17.922  Â
 Max. Initial penetration 1.703995895E-05 was detected between contactÂ
 element 1215073 and target element 1214953.                           Â
 constant set 12 and contact element type 12 has been set up. The     Â
 companion pair has real constant set ID 13. Both pairs should have   Â
 Max. Initial penetration 1.705299849E-05 was detected between contactÂ
 element 1215229 and target element 1215349.                           Â
 You may move entire target surface by : x= -2.583037783E-06, y=       Â
 1.685623545E-05, z= 4.453532888E-19,to reduce initial penetration.    Â
 constant set 13 and contact element type 12 has been set up. The     Â
 companion pair has real constant set ID 12. Both pairs should have   Â
 Max. Initial penetration 1.705332427E-05 was detected between contactÂ
 element 1215288 and target element 1215170.                           Â
 constant set 14 and contact element type 14 has been set up. The     Â
 companion pair has real constant set ID 15. Both pairs should have   Â
 Max. Initial penetration 1.70139613E-05 was detected between contact Â
 element 1215492 and target element 1215613.                           Â
 You may move entire target surface by : x= -1.535759236E-05, y=       Â
 -7.322515696E-06, z= 3.647501262E-20,to reduce initial penetration.   Â
 constant set 15 and contact element type 14 has been set up. The     Â
 companion pair has real constant set ID 14. Both pairs should have   Â
 Max. Initial penetration 1.701500617E-05 was detected between contactÂ
 element 1215552 and target element 1215433.                           Â
    D I S T R I B U T E D  D O M A I N  D E C O M P O S E R
 ...Number of elements: 1185364
 ...Number of nodes:   4251485
 ...Decompose to 15 CPU domains
 ...Element load balance ratio =    1.028
                     L O A D  S T E P  O P T I O N S
  LOAD STEP NUMBER. . . . . . . . . . . . . . . .    1
  TIME AT END OF THE LOAD STEP. . . . . . . . . . 0.10000  Â
  NUMBER OF SUBSTEPS. . . . . . . . . . . . . . .    2
  MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .   15
  STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .  YES
  TRANSIENT (INERTIA) EFFECTS
     THERMAL DOFS . . . . . . . . . . . . . . . .   ON
  TRANSIENT INTEGRATION PARAMETERS
     THETA. . . . . . . . . . . . . . . . . . . . 1.0000  Â
     OSCILLATION LIMIT CRITERION. . . . . . . . . 0.50000  Â
     TOLERANCE. . . . . . . . . . . . . . . . . . 0.0000  Â
  TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)Â
  CONVERGENCE CONTROLS
     LABEL  REFERENCE   TOLERANCE NORM    MINREF
      HEAT   0.000      0.1000E-03  2    0.1000E-02
  PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
  DATABASE OUTPUT CONTROLS
     ITEM    FREQUENCY  COMPONENT
      ALL      NONE             Â
     NSOL       ALL             Â
     RSOL       ALL             Â
     EANG       ALL             Â
     VENG       ALL             Â
     FFLU       ALL             Â
     CONT       ALL             Â
     MISC       ALL             Â
 SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr        Â
 MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS HAS BEEN MODIFIED            Â
 TO BE, NEQIT = 1000, BY SOLUTION CONTROL LOGIC.                      Â
 RADIOSITY SOLVER CALCULATION
Case 2: No error 5mm mesh size of the plate, other bodies 20mm
Solver Output
 * prohibited.                                                *
 * Notice.                                                    *
 * agreement.                                                 *
 * re-export.                                                 *
 * licenses).                                                 *
 2022 R2
 Discovery 2022 R2 Â
 SpaceClaim 2022 R2Â
 Autodyn 2022 R2
 LS-DYNA 2022 R2
 Chemkin 2022 R2
 FENSAP-ICE 2022 R2Â
 TurboGrid 2022 R2 Â
 ICEM CFD 2022 R2
 Aqwa 2022 R2
 Speos 2022 R2 Â
 Speos HPC 2022 R2 Â
 optiSLang 2022 R2 Â
 Additive 2022 R2
 Viewer 2022 R2Â
 INPUT FILE NAME             = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA\dummy.dat
 OUTPUT FILE NAME            = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA\solve.out
 CURRENT JOBNAME=file0 13:16:55 DEC 07, 2024 CP=     0.156
 *** NOTE ***                           CP =      3.406  TIME= 13:17:00
 *GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 13.2833333  Â
 TITLE=
 ACT Extensions:
     LSDYNA, 2022.2
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA\
 PARAMETER _WB_SOLVERFILES_DIR(1) = E:\Test_Beam_1.63MW_Sig5mm\Test_Radiation_files\dp0\SYS-29\MECH\
 MASS       = TONNE (Mg)
 TOFFSET    = 273.0
 FORCE      = NEWTON (N)
 00000000 VERSION=WINDOWS x64  13:17:00 DEC 07, 2024 CP=     3.406
 ***** ROUTINE COMPLETED ***** CP =       10.750
 --- Number of total nodes = 351363
 --- Number of solid elements = 60438
 --- Number of total elements = 61398
 *GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 13.2836111  Â
      NAME = MAX_TEMP                      Â
 ITEM/COMP = TEMPMAX
      NODE =        0
      NAME = MIN_TEMP                      Â
 ITEM/COMP = TEMPMIN
      NODE =        0
 Estimated Increment Needed, le*le/alpha, Body 7: 0.481464
     13748 ELEMENTS (OF     61398 DEFINED) SELECTED FROM
   43202 SELECTED NODES BY ESLN COMMAND.
 NUMBER OF RDSF ELEMENT FACE LOADS STORED =     14400
 IN RANGE        1 TO    351363 STEP         1
    351363 NODES (OF    351363 DEFINED) SELECTED BY NSEL COMMAND.
              ITERATIONS = 100
     29398 ELEMENTS (OF     61398 DEFINED) SELECTED FROM
 IN RANGE        1 TO    134026 STEP         1
     61398 ELEMENTS (OF     61398 DEFINED) SELECTED BY ESEL COMMAND.
 TIME= 0.10000  Â
 FOR 3D ENCLOSURES.
 FOR 2D ENCLOSURES.
NUMBER OF RADIATION NODES CREATED =Â Â Â Â Â 14402
NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â Â Â 14400
FULL NUMBER OF RADIATION NODES CREATED =Â Â Â Â Â 14402
FULL NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED =Â Â Â Â 14400
 IN RANGE        1 TO    365765 STEP         1
    365765 NODES (OF    365765 DEFINED) SELECTED BY NSEL COMMAND.
 IN RANGE        1 TO    148426 STEP         1
     75798 ELEMENTS (OF     75798 DEFINED) SELECTED BY ESEL COMMAND.
     29398 ELEMENTS (OF     75798 DEFINED) SELECTED FROM
 IN RANGE        1 TO    394205 STEP         1
    394205 NODES (OF    394205 DEFINED) SELECTED BY NSEL COMMAND.
 IN RANGE        1 TO    176392 STEP         1
    103764 ELEMENTS (OF    103764 DEFINED) SELECTED BY ESEL COMMAND.
 *ENDIF
 *** NOTE ***                           CP =     16.109  TIME= 13:17:01
 TOTAL OF   42366 DEFINED ELEMENT FACES.
 # ENCLOSURE =    1 # SURFACES = 42366 # NODES = 42842
     Tolerance     = 0.001
     row sum total should be                  = 42366.0000
     row sum total before forcing symmetry    = 42365.9937
     row sum total after forcing symmetry     = 42365.9937
     row sum total after smoothing            = 42365.9997
     Raw rowsum error min                     = -4.5061e-05
     Raw rowsum error mean                    = -1.4800e-07 +/- 4.5422e-07
     Symmetric rowsum error min               = -4.5061e-05
     Symmetric rowsum error mean              = -1.4800e-07 +/- 5.8700e-08
     Smoothed rowsum error min                = -2.3842e-07
     Smoothed rowsum error max                = 4.7684e-07
     Smoothed rowsum error mean               = -7.6563e-09 +/- 1.4846e-10
TIME OF CALCULATION FOR THIS ENCLOSURE =Â Â Â 28.7812Â Â Â
 *** WARNING ***                        CP =     58.953  TIME= 13:17:41
 *** WARNING ***                        CP =     59.047  TIME= 13:17:42
 *** NOTE ***                           CP =     59.484  TIME= 13:17:42
 E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA\file0.err ) for    Â
 00000000 VERSION=WINDOWS x64  13:17:42 DEC 07, 2024 CP=    59.594
 *** NOTE ***                           CP =     59.812  TIME= 13:17:42
 *** NOTE ***                           CP =     60.891  TIME= 13:17:42
 same behavior.                                                        Â
 element 133149 and target element 133270.                             Â
 same behavior.                                                        Â
 element 133209 and target element 133090.                             Â
 element 133412 and target element 133534.                             Â
 element 133473 and target element 133353.                             Â
 element 133629 and target element 133749.                             Â
 element 133688 and target element 133570.                             Â
 element 133892 and target element 134013.                             Â
 element 133952 and target element 133833.                             Â
 ...Number of elements: 103764
 ...Number of nodes:   394205
 ...Element load balance ratio =    1.101
      ALL      NONE             Â
     NSOL       ALL             Â
     RSOL       ALL             Â
     EANG       ALL             Â
     VENG       ALL             Â
     FFLU       ALL             Â
     CONT       ALL             Â
     MISC       ALL             Â
 ENCLOSURE NUMBER=  1
 RADIOSITY SOLVER CONVERGED AFTER 104 ITERATIONS
 TIME OF RADIOSITY SOLVER FOR ENCLOSURE=  15.1562  Â
 RAD FLUX CONVERGENCE VALUE=  1.00000    CRITERION= 0.100000E-04
           **** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
 CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
 TOTAL MASS = 0.65239  Â
                          MOM. OF INERTIA        MOM. OF INERTIA
 CENTER OF MASS           ABOUT ORIGIN       ABOUT CENTER OF MASS
 XC = -200.00         IXX =  0.2670E+06     IXX =  0.2409E+06
 YC = -200.00         IYY =  0.2670E+06     IYY =  0.2409E+06
 ZC = -4.9274         IZZ =  0.3405E+06     IZZ =  0.2883E+06
                        IXY = -0.2610E+05     IXY =  0.2033E-03
                        IYZ =  -642.9         IYZ =  0.5181E-02
                        IZX =  -642.9         IZX = -0.4760E-02
 *** MASS SUMMARY BY ELEMENT TYPE ***
 TYPE     MASS
    1 0.921662E-01
    2 0.921662E-01
    3 0.921662E-01
    4 0.921662E-01
    5 0.138721  Â
    6 0.138721  Â
    7 0.628000E-02
 Range of element maximum matrix coefficients in global coordinates
 Maximum = 7563.16915 at element 133396.                               Â
 Minimum = 558.91788 at element 49878.                                 Â
  *** ELEMENT MATRIX FORMULATION TIMES
    TYPE   NUMBER  ENAME     TOTAL CP AVE CP
       1     3009 SOLID279     0.266  0.000088
       2     3009 SOLID279     0.234  0.000078
       3     3009 SOLID279     0.188  0.000062
       4     3009 SOLID279     0.094  0.000031
       5     8201 SOLID279     0.656  0.000080
       6     8201 SOLID279     0.641  0.000078
       7    32000 SOLID279     1.203  0.000038
       8      120 CONTA174     0.000  0.000000
       9      120 TARGE170     0.000  0.000000
      10      120 CONTA174     0.016  0.000130
      11      120 TARGE170     0.000  0.000000
      12      120 CONTA174     0.000  0.000000
      13      120 TARGE170     0.000  0.000000
      14      120 CONTA174     0.000  0.000000
      15      120 TARGE170     0.000  0.000000
      16    14400 SURF252      0.094  0.000007
      17    27966 SURF252      0.141  0.000005
 Time at end of element matrix formulation CP = 96.15625.              Â
    HT FLOW CONVERGENCE VALUE=  3.567     CRITERION= 0.4041E-01
 DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
 Number of equations =     113756,   Maximum wavefront =     1
 *** NOTE ***                           CP =    100.406  TIME= 13:18:17
 This solution uses the GPU accelerator capability.                    Â
 Process memory allocated for solver             =   10.236 MB
 Process memory required for in-core solution    =    9.777 MB
 Process memory required for out-of-core solution =    8.174 MB
 Total memory allocated for solver               =  239.611 MB
 Total memory required for in-core solution      =  230.076 MB
 Total memory required for out-of-core solution  =  176.083 MB
 The Distributed Sparse Matrix Solver is currently running in the      Â
 in-core memory mode. This memory mode uses the most amount of memory Â
 in order to avoid using the hard drive as much as possible, which mostÂ
 often results in the fastest solution time. This mode is recommended Â
 if enough physical memory is present to accommodate all of the solver Â
 data.        Â
 Distributed sparse solver maximum pivot= 59400.7117 at node 64209 TEMP.
 Distributed sparse solver minimum pivot= 2111.0024 at node 256390 TEMP.
 Distributed sparse solver minimum pivot in absolute value= 2111.0024 at
 node 256390 TEMP.                                                     Â
 *** WARNING ***                        CP =    100.516  TIME= 13:18:18
 The Distributed Sparse Matrix Solver was not able to sufficiently     Â
 utilize the GPU accelerator device(s) during this equation solution.  Â
 This can be caused by one or more factors such as: the size of the    Â
 system of equations being solved; using older or less powerful GPU    Â
 hardware relative to the CPU core(s) involved; having insufficient    Â
 available memory on the GPU device. The check for GPU performance    Â
 terminates for the remainder of this session.                         Â
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC=  1980.  Â
    HT FLOW CONVERGENCE VALUE= 0.9189E-08 CRITERION=  3.213    <<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION  1
 ENCLOSURE NUMBER=  1
 RADIOSITY SOLVER CONVERGED AFTER 209 ITERATIONS
 TIME OF RADIOSITY SOLVER FOR ENCLOSURE=  30.1094  Â
 RAD FLUX CONVERGENCE VALUE= 0.999699    CRITERION= 0.100000E-04
    HT FLOW CONVERGENCE VALUE= 0.2924E+07 CRITERION=  746.6  Â
   EQUIL ITER  2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC=  1.536  Â
    HT FLOW CONVERGENCE VALUE= 0.1293E-07 CRITERION=  687.8    <<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION  2
 ENCLOSURE NUMBER=  1
 RADIOSITY SOLVER CONVERGED AFTER  23 ITERATIONS
 TIME OF RADIOSITY SOLVER FOR ENCLOSURE=  3.29688  Â
 RAD FLUX CONVERGENCE VALUE= 0.352322E-05 CRITERION= 0.100000E-04
 RADIOSITY FLUX CONVERGED AFTER ITERATION=   3 SUBSTEP=   1
    HT FLOW CONVERGENCE VALUE=  1976.     CRITERION=  687.8  Â
   EQUIL ITER  3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1866E-02
    HT FLOW CONVERGENCE VALUE= 0.1282E-07 CRITERION=  687.8    <<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION  3
  *** ELEMENT RESULT CALCULATION TIMES
       1     3009 SOLID279     0.250  0.000083
       3     3009 SOLID279     0.141  0.000047
       4     3009 SOLID279     0.047  0.000016
       5     8201 SOLID279     0.531  0.000065
       6     8201 SOLID279     0.562  0.000069
       7    32000 SOLID279     0.609  0.000019
       8      120 CONTA174     0.016  0.000130
      16    14400 SURF252      0.656  0.000046
      17    27966 SURF252      0.938  0.000034
  *** NODAL LOAD CALCULATION TIMES
       1     3009 SOLID279     0.031  0.000010
       2     3009 SOLID279     0.031  0.000010
       3     3009 SOLID279     0.047  0.000016
       4     3009 SOLID279     0.031  0.000010
       5     8201 SOLID279     0.047  0.000006
       6     8201 SOLID279     0.078  0.000010
       7    32000 SOLID279     0.250  0.000008
      10      120 CONTA174     0.000  0.000000
      16    14400 SURF252      0.000  0.000000
      17    27966 SURF252      0.000  0.000000
 *** LOAD STEP    1  SUBSTEP    1 COMPLETED.   CUM ITER =     3
 *** TIME = 0.500000E-01    TIME INC = 0.500000E-01
    HT FLOW CONVERGENCE VALUE= 0.2897E+07 CRITERION=  747.6  Â
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC=  1.287  Â
    HT FLOW CONVERGENCE VALUE= 0.1235E-07 CRITERION=  695.1    <<< CONVERGED
 ENCLOSURE NUMBER=  1
 RADIOSITY SOLVER CONVERGED AFTER  21 ITERATIONS
 TIME OF RADIOSITY SOLVER FOR ENCLOSURE=  3.01562  Â
 RAD FLUX CONVERGENCE VALUE= 0.287387E-05 CRITERION= 0.100000E-04
 RADIOSITY FLUX CONVERGED AFTER ITERATION=   1 SUBSTEP=   2
    HT FLOW CONVERGENCE VALUE=  1658.     CRITERION=  695.1  Â
   EQUIL ITER  2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1565E-02
    HT FLOW CONVERGENCE VALUE= 0.1329E-07 CRITERION=  695.1    <<< CONVERGED
 *** LOAD STEP    1  SUBSTEP    2 COMPLETED.   CUM ITER =     5
 *** TIME = 0.100000        TIME INC = 0.500000E-01
 *** MAPDL BINARY FILE STATISTICS
 BUFFER SIZE USED= 16384
       2.625 MB WRITTEN ON ELEMENT SAVED DATA FILE: file0.esav
       3.062 MB WRITTEN ON ASSEMBLED MATRIX FILE: file0.full
      10.750 MB WRITTEN ON RESULTS FILE: file0.rth
 *************** Write FE CONNECTORS *********
 WRITE OUT CONSTRAINT EQUATIONS TO FILE= file.ce        Â
 *************** FINISHED SOLVE FOR LS 1 *************
 *GET _WALLASOL FROM ACTI ITEM=TIME WALL VALUE= 13.3205556  Â
 FINISH SOLUTION PROCESSING
 ***** ROUTINE COMPLETED ***** CP =      156.156
 00000000 VERSION=WINDOWS x64  13:19:14 DEC 07, 2024 CP=   156.156
         ***** MAPDL RESULTS INTERPRETATION (POST1) *****
 *** NOTE ***                           CP =    156.391  TIME= 13:19:14
 Reading results into the database (SET command) will update the current
 displacement and force boundary conditions in the database with the   Â
 values from the results file for that load set. Note that any        Â
 subsequent solutions will use these values unless action is taken to  Â
 either SAVE the current values or not overwrite them (/EXIT,NOSAVE).  Â
 Set Encoding of XML File to:ISO-8859-1
 Set Output of XML File to:
    PARM,    ,    ,    ,    ,    ,    ,    ,    ,    ,    ,    ,
 DATABASE WRITTEN ON FILE parm.xml        Â
 EXIT THE MAPDL POST1 DATABASE PROCESSOR
 ***** ROUTINE COMPLETED ***** CP =      156.391
 *GET _WALLDONE FROM ACTI ITEM=TIME WALL VALUE= 13.3205556  Â
 PARAMETER _PREPTIME =    1.000000000  Â
 PARAMETER _SOLVTIME =    133.0000000  Â
 PARAMETER _POSTTIME =    0.000000000  Â
 PARAMETER _TOTALTIM =    134.0000000  Â
 *GET _DLBRATIO FROM ACTI ITEM=SOLU DLBR VALUE= 1.10090012  Â
 *GET _COMBTIME FROM ACTI ITEM=SOLU COMB VALUE= 0.298892600  Â
 *GET _SSMODE  FROM ACTI ITEM=SOLU SSMM VALUE= 2.00000000  Â
 *GET _NDOFS   FROM ACTI ITEM=SOLU NDOF VALUE= 113756.000  Â
 /FCLEAN COMMAND REMOVING ALL LOCAL FILES
 --- Total number of nodes = 351363
 --- Total number of elements = 61398
 --- Element load balance ratio = 1.10090012
 --- Time to combine distributed files = 0.2988926
 --- Sparse memory mode = 2
 --- Number of DOF = 113756
 EXIT MAPDL WITHOUT SAVING DATABASE
 NUMBER OF WARNING MESSAGES ENCOUNTERED=         3
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=         0
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2022 R2Â Â Â Â Â Â Â Â Â Â Â Build: 22.2Â Â Â Â Â Â Update: UP20220516Â Â Platform: WINDOWS x64
Date Run: 12/07/2024Â Â Time: 13:19Â Â Â Â Process ID: 454368
Operating System: Windows 10Â (Build: 19045)
Processor Model: Intel(R) Core(TM) i9-14900K
Compiler: Intel(R) Fortran Compiler Version 19.0.5Â (Build: 20190815)
         Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)
         Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
         BLAS Library supplied by Intel(R) MKL
Number of machines requested           :   1
Total number of cores available        :  32
Number of physical cores available     :  24
Number of processes requested          :  15
Number of threads per process requested :Â Â Â 1
Total number of cores requested        :  15 (Distributed Memory Parallel)             Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
Number of GPUs requested               :   1
GPU Acceleration: NVIDIA Library Requested and Enabled
GPU Device with ID =Â 0 is: NVIDIA RTX A4000
GPU Driver Version: 12.40
CUDA Version: 11.0
Job Name: file0
Input File: dummy.dat
 Core               Machine Name  Working Directory
    0               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    1               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    2               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    3               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    4               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    5               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    6               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    7               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    8               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
    9               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
   10               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
   11               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
   12               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
   13               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
   14               pc-thofell-2  E:\Test_Beam_1.63MW_Sig5mm\_ProjectScratch\Scr13EA
Latency time from master to core    1 =   1.905 microseconds
Latency time from master to core    2 =   2.263 microseconds
Latency time from master to core    3 =   1.836 microseconds
Latency time from master to core    4 =   1.834 microseconds
Latency time from master to core    5 =   1.874 microseconds
Latency time from master to core    6 =   1.939 microseconds
Latency time from master to core    7 =   1.947 microseconds
Latency time from master to core    8 =   3.367 microseconds
Latency time from master to core    9 =   3.428 microseconds
Latency time from master to core   10 =   3.533 microseconds
Latency time from master to core   11 =   3.458 microseconds
Latency time from master to core   12 =   3.346 microseconds
Latency time from master to core   13 =   3.919 microseconds
Latency time from master to core   14 =   3.417 microseconds
Communication speed from master to core    1 = 14717.79 MB/sec
Communication speed from master to core    2 = 15699.82 MB/sec
Communication speed from master to core    3 = 16146.94 MB/sec
Communication speed from master to core    4 = 15991.68 MB/sec
Communication speed from master to core    5 = 16511.53 MB/sec
Communication speed from master to core    6 = 16200.23 MB/sec
Communication speed from master to core    7 = 15609.45 MB/sec
Communication speed from master to core    8 = 11298.80 MB/sec
Communication speed from master to core    9 = 11504.17 MB/sec
Communication speed from master to core   10 = 11157.13 MB/sec
Communication speed from master to core   11 = 10997.92 MB/sec
Communication speed from master to core   12 = 11750.88 MB/sec
Communication speed from master to core   13 = 11007.15 MB/sec
Communication speed from master to core   14 = 10467.92 MB/sec
Total CPU time for main thread                   :     139.9 seconds
Total CPU time summed for all threads            :     163.8 seconds
Elapsed time spent obtaining a license           :       1.1 seconds
Elapsed time spent pre-processing model (/PREP7)Â :Â Â Â Â Â Â Â 0.6 seconds
Elapsed time spent solution - preprocessing      :       1.1 seconds
Elapsed time spent computing solution            :      89.2 seconds
Elapsed time spent solution - postprocessing     :       0.3 seconds
Elapsed time spent post-processing model (/POST1) :Â Â Â Â Â Â Â 0.0 seconds
Equation solver used                             :           Sparse (symmetric)
Equation solver computational rate               :      65.7 Gflops
Sum of memory used on all processes              :    4173.0 MB
Sum of memory allocated on all processes         :   16448.0 MB
Physical memory available                        :       192 GB
Total amount of I/O written to disk              :      13.8 GB
Total amount of I/O read from disk               :       0.3 GB
+------------------ E N DÂ Â M A P D LÂ Â S T A T I S T I C S -------------------+
 |                              RUN COMPLETED                              |
 | Ansys MAPDL 2022 R2        Build 22.2        UP20220516   WINDOWS x64 |
 | Database Requested(-db) 1024 MB   Scratch Memory Requested     1024 MB |
 | Maximum Database Used    264 MB   Maximum Scratch Memory Used   435 MB |
 |       CP Time     (sec) =       163.781      Time = 13:19:19       |
 |       Elapsed Time (sec) =       146.000      Date = 12/07/2024     |
December 10, 2024 at 3:59 pm
dlooman
Ansys EmployeeIt could be a bug, but you made a very big mesh when you set the element size to 1mm. You may have hit an untrapped limit of your computer. Are you running on a lap top with limited memory? Do you have access to normal tech. support?
5654
1890
1404
1303
