May 13, 2020 at 12:45 am
oahlatli
SubscriberHi, I am working on radial fan with medium pressure. Experimentel test setup has inlet and outlet duct. We use the valve in the outlet duct to pressurize the fan.Â
To simulate this situation, I define the following conditions as boundary condition in fluent.
1. For free suction at the inlet (to simulate atmosphere), Gauge Pressure inlet= 0 Pa
2. For the static pressure at the outlet, Gauge pressure=500 Pa (sample)
3.MFR Domain has frame motion at desired rotational speedÂ
For this condition,I got different result from experimental result. I would like to ask to you, my boundary condition is true for this setup?
Thank you.
Viewing 0 reply threads
- The topic ‘radial fan performans test bench’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1256
1118
1015
