October 6, 2023 at 11:15 am
Abdur Rahman
SubscriberHi,Â
 I am trying to obtain unbalance magnetic force acting on the rotor of a PMSM. Could anybody suggest me how can I obtain radial and tangential force acting on the rotor of a PMSM? Can I get it directly using field calculator, if so, please explain step by step? Also, please explain how can I write the Maxwell stress tensor formula, as shown in the figure, in the field calculator.  Thanks.Â
Fx can also be expressed as eqn (4)
October 12, 2023 at 3:15 pm
DELI
Ansys Employeehi, you can use field calculator to create named expression for radial and tangential force.
Br=ScalarX(ToCylindrical(
,offset<0mm, 0mm, 0mm>)) Bt=ScalarY(ToCylindrical(
,offset<0mm, 0mm, 0mm>)) mu0=1.25664E-06
Fmst_r=Â /(-(*(Br, Br), *(Bt, Bt)), *(mu0, 2))
Fmst_t=Â /(*(Br, Bt), mu0)
October 12, 2023 at 3:29 pm
GLUO
Ansys EmployeeHello,
Please use the radial flux density to get the radial force.
For radial flux density in field calculator:
Input > Quantity > B
Vector > Scal? > ScalarX
Input > Function > Scalar > PHI
Scalar > Trig > Cos
General > *
General > Smooth
Vector > Scal? > ScalarY
Scalar > Trig > Sin
General > *
General > +
Select Add and set the name of expression as B_radial -
October 12, 2023 at 3:33 pm
GLUO
Ansys EmployeeYou can also rightclick the design name to enable harmonic force calculation. The tangential and the radial force will be ready in the report. MST is defined as Fmst_r=(Br^2-Bt^2)/(2*mu0), Fmst_t=Br*Bt/mu0.
GLÂ
- The topic ‘Radial and Tangential Magnetic force on rotor of a PMSM’ is closed to new replies.
- Plotting Ex, Ey and Ez in vector forms individually
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
2773
960
835
599
591
