June 19, 2020 at 3:39 pm
AlexC
SubscriberFor this type of geometry (see below), if I want to select all the edges in the red box (when I do meshing), is there a quick way to do it?
I’m asking this because quite often I need to handle much more complicated cases than this. It’s quite annoying to select them one by one and I can easily miss some or pick nearby edges.
In some software (for example COMSOL), they have tools called for "select" and "deselect". I can simply move the mouse to draw a box to select or deselect all the edges within that box. It’s very convenient. I wonder if there are similar tools in Ansys Fluent. I didn’t find them.Â
Thank you!Â
Alex
June 22, 2020 at 11:56 am
Karthik Remella
AdministratorPlease go to the Views Tab. Under the 'Mouse' group, please change the default setting of your left from 'mouse-rotate' to 'mouse-multi-select'. You should then be able to use the left-click to draw the box and select multiple elements in Fluent.
I hope this is what you are looking for.
Thank you.
Karthik
June 23, 2020 at 3:46 am
Keyur Kanade
Ansys Employeehere is box selection option.Â
you can also look atÂ
https://www.youtube.com/watch?v=ByVtViHQTMA
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
June 23, 2020 at 2:28 pm
June 23, 2020 at 2:36 pm
AlexC
SubscriberHello Keyur,
This works. Appreciate your help!Â
Thank you.Â
Alex
June 23, 2020 at 2:40 pm
Karthik Remella
AdministratorMy bad - I misunderstood the question. I put too much emphasis on the line "Â I wonder if there are similar tools in Ansys Fluent"Â was talking about Ansys Fluent.Â
Thanks, Keyur, for identifying and chiming in with the right answer.
Best,
Karthik
June 23, 2020 at 2:56 pm
AlexC
SubscriberOh sorry. I did make my question clear. Right I was asking how to do the named selection in meshing actually. Thank you Karthik.Â
Best,
Alex
- The topic ‘quick tools for selection and deselection in Ansys Mesh’ is closed to new replies.
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
3892
1414
1241
1118
1015
