January 29, 2020 at 9:10 am
Ingeniorator
SubscriberHi all,
I'm diving into the topic of functually graded materials in the domain of additive manufacturing recently and getting to know Ansys. There are a few good tutorials about lattice optimisation, but a few questions arose during testing.
1. How do you cut off the lattice densitiy below a certain threshold, say everything under a value of 0.1 gets set to 0 and disappears?
2. How do you get rid of the outer structure which stays solid after a common lattice optimisation? Is there a way to attain an open structure where the lattice structure reaches the outer bounds of the optimised body?
3. After implementing the lattice in the body in Spaceclaim, it gets faceted. How do you merge the facets after this step so that it can be properly meshed?
4. After trying to export an optimised and latticed structure as .step file to mesh in Hypermesh, the .step file itself was empty. Could someone have any pointers as to why this was the case?
Thank you very much for taking the time to read and hopefully answer my questions.
January 31, 2020 at 1:43 pm
Ingeniorator
SubscriberNo one?
February 12, 2020 at 8:58 am
February 17, 2020 at 8:41 am
Ingeniorator
SubscriberThank you very much for your extensive answer. However, there is one issue concerning the first question: The minimum lattice density is interpreted as a lower limit, meaning calculated values below this threshold get set to the (higher) allowed minimum value and do not vanish. Does this functionality exist in Ansys or would it be necessary to do a standard topology optimization first and then apply a lattice optimization on top of that?
- The topic ‘Questions concerning workflow for lattice optimisation’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
