July 26, 2022 at 2:26 pm
javat33489
SubscriberHi all.
I looked at the tutorials but didn't find any answers.
Please tell me who knows.
- How to display max and min parameters (eg voltage) at a specified time in LS-DYNA postprocessor?
- How to make a cut in the results and look inside the part?
- How to select time and not state in the results when viewing?
- How to put measurement points on the model, so that later you can look at the results (for example, voltages) on them?
Thank you!
July 27, 2022 at 2:02 pm
Ram Gopisetti
Ansys EmployeeÂ
Hi Javat33849
1) can you be specific for ths question, the prepost will report you the min and max for the time on topleft corner.Â
2) you can use the section view from the bottom toolbar.Â
3) you can use the state option which will list you the timestamps along with the state numbers, upon selecting the entries of time you can see the graphics stage beeing updated with appropriate time stamp.Â
4) if i understand you correctly, there are no measurement points but you can use node based reporting using the DATABASE_HISTORY option.Â
cheers, RamÂ
July 27, 2022 at 5:37 pm
javat33489
SubscriberThanks a lot! I'll check it all out.
- The topic ‘Questions about LS-DYNA results’ is closed to new replies.
1545
1386
1230
