Question regarding flow rate of water through a porous zone
    • Keyur Kanade
      Hello Fluids Experts, ?
      I am required to estimate the flow rate of water through a porous zone. I know the expected pressure drop and the permeability of the zone. Is it possible to get a theoretical estimate of the flow rate based on these variables?
      Thank you in advance for your help
    • Karthik Remella
      Administrator
      Hi @kkanade ?,
      Darcy's law provides a relationship for estimating the instantaneous flow rate through a homogeneous porous media of permeability K with a known pressure drop across its thickness.
      Mathematically,
      Q = K * A * del_P / (mu * L)
      Where,
      Q - flow rate [m^3/s]
      K - permeability [m^2]
      A - cross-sectional area [m^2]
      del_P - pressure drop [Pa]
      mu - dynamic viscosity [Pa-s]
      L - length across the porous media (thickness) [m]
      Hope this helps.
  • The topic ‘Question regarding flow rate of water through a porous zone’ is closed to new replies.
