August 12, 2024 at 6:21 pm
August 13, 2024 at 6:03 am
Akshay Maniyar
Ansys EmployeeHi,
Please check the below AIC video on remote points.
Utilizing Remote Points Properly - Lesson 4 - ANSYS Innovation Courses
Thanks,
Akshay Maniyar
August 13, 2024 at 8:40 am
K Kramer
SubscriberHi,
I did, but alas the video does not really elaborate on the question. In order to be able to solve the system of equations, the remote point must be linked to the scoped nodes in the global stiffness matrix through some mathematical relation, the nature of which i would like to understand (if the remote force point was just a dependent point whose displacement is computed as the mean (or some other measure) of the displacements of the scoped nodes, its displacement could simply be calculated ex post and the application of forces to the remote point would make no sense).
August 13, 2024 at 11:49 am
Akshay Maniyar
Ansys EmployeeHi,
Deformable behavior is similar to the Mechanical APDL constraint defined by the RBE3 command and rigid is similar to the CERIG command. Please check the Ansys help link for more details about force distribution.
Thanks,
Akshay Maniyar
August 13, 2024 at 12:49 pm
K Kramer
SubscriberÂ
Ah, ok. So from what I gather, the force at the remote point is distributed to the scoped nodes in equal parts if behavior is set to "deformable" (since no weighting factors are specified)?
5649
1885
1403
1303
