Question about the maxwell-stefan equations written in fluent theory guide
TAGGED: fluent, multicomponent, multicomponent-diffusion
October 4, 2024 at 4:35 am
kimjh12
SubscriberHi, I have question about maxwell-stefan equations written in the fluent theory guide Fluent 2024 R2.
In chapter 7.1.1.3.2, there are definitions and equations related to Maxwell-Stefan equations.Â
My question is the formula $M_{w,m}$ which is defined as $\sum_{i=1}^N\frac{Y_i}{M_{w,i}}$, where $Y_i$ is a mass fraction of $i$th species, and $M_{w,i}$ is a molecular weight of $i$th species.
Also, there is a remark related to the formula; 'a subscript used to define a mean molecular weight in the mixture'.
I wonder if the expression is defined properly.
In my thought, $M_{w,m}$ should be inverse of $\sum_{i=1}^N\frac{Y_i}{M_{w,i}}$.Â
The proof is as follows. By using the related quantities between mass fraction $Y_i$ and mole fraction $X_i$, $\sum_{i=1}^N\frac{Y_i}{M_{w,i}}$ is equal to $\sum_{i=1}^N\frac{X_iM_{w,i}}{\sum_{j=1}^N X_jM_{w,j}}\frac{1}{M_{w,i}}$.
Since $\sum_{i=1}^N X_i=1$ by definition of the mole fraction, we can further simplify the expression. As a result, $\sum_{i=1}^N\frac{Y_i}{M_{w,i}}$ is equal to $\frac{1}{\sum_{j=1}^N\frac{X_j}{M_{w,j}}}$, which is inverse of the mean molecular weight in the mixture.Â
Thank you.Â
October 24, 2024 at 4:17 pm
Ahmed Hussien
Ansys EmployeeYour logic seems correct. I will further investigate and let you know.Â
October 25, 2024 at 7:35 pm
Ahmed Hussien
Ansys EmployeeÂ
I checked this and you are right. There is a typo in the documentation and it will be fixed in the next release. However, the implementation in the code is correct. It should not affect the solution in your case.
5899
1306
