3D Design
3D Design
question about slicing
    • sentenza
      Good morning, i have a simple question for you:
      I learned that i have to slice a component to have different mesh on the same part. When i give form new part command with share topology active, is it equivalent in analysis results than to have a single solid part?
      thanks for the help
    • raul.raghav
      When you slice a geometry, you can achieve a better mesh quality. By slicing you can generate sweepable bodies which can meshed with hex elements, thereby improving mesh quality and reducing the number of mesh elements.
      By forming a new part with shared topology, you are creating a multi-body part but at the same time ensuring that you have a conformal mesh across all the bodies of the new part.
    • sentenza
      thankyou, very clear answer!
  • The topic ‘question about slicing’ is closed to new replies.
