August 30, 2024 at 7:29 am
JooJaehoon
SubscriberHello!ÂI'm conducting static analysis on plateÂI inflict 5.88 MPA clamping pressure using other plate indirectlyÂI got equivalent stress distribution and I attached a picture, but, I have doubt about this result because of it's randomness.ÂShould I use this result? or, how can I decrease randomness of result?ÂThank you.Â
September 1, 2024 at 8:01 pm
One way to smooth the contact pressure distribution is to change the default normal stiffness.Â
Change Normal Stiffness to Factor and use a value of 0.1 or 0.01 instead of the default value of 1.0 and change Update Stiffness to Every Iteration.
Another thing you can do is use a finer mesh in the contact region. This is easily done using a Contact Mesh Sizing control.
Take the free course on Contact Mechanics.
September 2, 2024 at 8:50 am
JooJaehoon
SubscriberHello ! Peter !
Thank you for applying to my qustion.
I'll try to modify stiffness term and check a result
have a good day.
September 5, 2024 at 2:13 am
JooJaehoon
SubscriberI solved problem!
I'm glad to your advice!
JooJaehoon
SubscriberI solved a problem!
