Question about radiation heat in ANSYS mechanical.
    • Ilaria Salerno
      I'm a beginner and I'm working on a university project where I need to perform a thermal analysis on a simplified satellite model. When I set up the radiative heat transfer, the software asks me to set the emissivity coefficient and the ambient temperature. I've conducted several simulations with different ambient temperature values and noticed that it significantly affects the temperature of the satellite. Since it's LEO, I kept it within a range of -100 to +60 (°C), instead of setting it to 0 K. Do you think this approach is correct, or is there a way to convey to ANSYS that I'm in a vacuum and thus don't want to consider the ambient temperature?
      Thank you for your help.
      Radiative Heat Transfer works the same whether you are in a vacuum or not. The ambient temperature in Radiative Heat Transfer refers to the space around an object.  That space could be the walls of a room or it could be the vacuum of dark space.
      Convective Heat Transfer also uses the term ambient temperature, but that refers to fluid motion that brings in new fluid at ambient temperature into contact with the object then the heat is carried away by the warmed fluid. You can’t do that in a vacuum.
      Here is an article I found.
    • Ilaria Salerno
      Thank you for your answer, Peter. My issue is that I'm unsure about the ambient temperature that I should set when simulating the radiative heat transfer from the satellite's external surfaces to the space, which is a required input besides the emissivity coefficient. Many suggest to set it to 2.7K, which is the estimated temperature of deep space, but I found that the steady-state solution drops in a not-realistic way (considering that I have also other thermal inputs, such as the solar direct radiation). Do you have any advice?
      Read this paper to learn about:
    • l_srf
      Hi Ilaria, would you mind sharing how you created a vacuum environment for your satellite? I have a similar case to simulate (satellite in a vacuum chamber and in space) and don't know how to set up a vacuum (i.e no air) in Ansys Fluent. Thanks
      • Ilaria Salerno
        Hi Laryssa. In the end, I set up the ambient temperature at 2.4 K assuming that the satellite radiates in cold space. I don't know if that's the right solution, but from my understanding, Ansys Mechanical doesn't automatically simulate the presence of air or any other gas unless you incorporate it into your analysis. I'm not sure how that works for Fluent.
Viewing 4 reply threads
  • The topic ‘Question about radiation heat in ANSYS mechanical.’ is closed to new replies.
