Photonics
Photonics
Question about Material Plugin Framework
    • zzp2002
      Hello, everyone.
      In fact, I used graphene in FDTD simulation. I wanted to consider the saturable absorption effect of graphene, which is related to light intensity.
      Therefore, I wanted to obtain the electric field of light in different regions (possibly each grid) to calculate the light intensity of each region, in order to achieve the differentiation of graphene absorption in different regions.
      Therefore, I used the Material Plugin Framework function to write C++code for graphene, which requires relevant instructions to extract the electric field of each grid. Can the Material Plugin Framework function of FDTD be implemented currently? Is there any code that can extract the light intensity of each grid in C++code?
      Thanks for you reply.
    • Kirill
      Dear Subscriber,
      This topic appears to be a duplicate of the discussion happening in another thread 材料编写问题 and will be closed.
  • The topic ‘Question about Material Plugin Framework’ is closed to new replies.
