July 5, 2024 at 12:21 am
JooJaehoon
SubscriberHello!
I'm conducting static analysis about break-away phenomenon of component
when external force applied at component, sliding occured after component deformed
Static friction used when deformation occured and dynamic friction used when sliding occured
In the end, components get new equilibrium condition and static analysis ended.
What force applied in this series of processes?
Is static friction is applied in the end of this process or not?
I want to know mechanism of calculating friction force at interface when sliding occuring.
I attached figure about break-away processÂ
thank you
July 8, 2024 at 3:16 pm
Ashish Khemka
Forum ModeratorHi,
It seems that John did answer your question.
Ashish Khemka
July 10, 2024 at 8:38 am
JooJaehoon
SubscriberMy computer had some problem, I thought the first question had not posted so I posted same question.
thank you for applying
- The topic ‘Question about friction analysis when sliding occured’ is closed to new replies.
5649
1885
1404
1303
