April 7, 2024 at 7:50 am
lzfneu
SubscriberHi,
I want to consult you how to implement coordinate transformation with time to realize the purpose of changing loading position of heat generation rate with time for the model. It's better to have a step-by-step demonstration.
Any help will be appreciated and thanks in advance.
April 8, 2024 at 10:23 am
Aniket Chavan
Forum ModeratorCan you please check if the following helps:
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/act_script/act_script_examples_python_cs_parameter.html
-Aniket
- The topic ‘How to implement coordinate transformation with time in ansys workbench’ is closed to new replies.
