June 13, 2023 at 9:15 am
aitor.amatriain
SubscriberHello,
I all books about finite volume method it is said that the central differencing scheme is just the mean between the cells that share a face. However, in Ansys Fluernt there is another term that contains the gradients of the variables:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/flu_th/flu_th_SolveDiscretization_spatial.html?q=central%20differencing
What is the purpose of adding this term? As far as I am concerned, the "standard" expression is also second-order acccurate.
Thank you,
Aitor
June 13, 2023 at 12:21 pm
Federico
Ansys EmployeeHello,Â
the inclusion of the gradient term provides a higher-order correction to the central differencing scheme, enabling Fluent to better capture complex flow phenomena, e.g. steep gradients and/or discontinuities, and deliver improved accuracy compared to the standard approach.
- The topic ‘Question about central differencing scheme in Fluent’ is closed to new replies.
