September 18, 2024 at 9:04 am
fachienchong
SubscriberHello,
I need to use lumopt for inverse design, and during the simulation process, I found that my model remained unchanged for a long time. In the log file, I noticed the following issues. Should I adjust the auto shutoff time.And i noticed that my simulation process has lasted for several days,is it works normally?
thanks
best
September 18, 2024 at 3:45 pm
Guilin Sun
Ansys EmployeeIt does not diverge and autoshutoff is still 1 for so long simulation time might mean that you are using metal or periodic boundaries conditions without PML boundaries and with lossless materials. While for periodic structure with plane wave excitation you will for sure use the periodic boundaries in the periodic directions, and PML along propagation, non-periodic structures usually use PML surrounding the structures. When the substrate is a metal, to aovid long simulation time, one may use perfect electronic metal to replace the real metal material but the other side of boundary should be PML.
Other causes of long simulation time might be due to many other factors, please refer to
Ansys Insight: Slow convergence in FDTD
Please check your settings. If you still have the same issue, please post some screen copies here for the structure and settings. Otherwise please write a new post for any other questions.
September 19, 2024 at 1:44 pm
fachienchong
SubscriberHello,
Thank you for your response.
Does this mean that my model is not converging? I have confirmed my PML condition settings and reduced the simulation bandwidth, but the same situation still occurs. My simulation is based on the terahertz band, and the device size has reached the millimeter level. Is the grid setting related to it?
best -
September 19, 2024 at 9:39 pm
Guilin Sun
Ansys EmployeeIf you use the default automesh with mesh accuracy 2 or higher, it should be ok. However, from what you said, it might be because the simulation time is too short. The default 1000fs is for optic frequency. at the THz range, the simulation time is much longer. Please check the source signal and see if it is a complete pulse without cutting off.
In addition, if you can read those posts it would be helpful:
One suggestion is to signficantly increase the simulation time, and let the autoshutoff min to terminate it.
October 15, 2024 at 1:43 pm
fachienchong
SubscriberIn order to adapt to the terahertz band, I have increased the simulation time to 50000 fs, and the auto shutoff setting is shown in the following figure. And adjust the simulation area settings.
It can be seen that the simulation record is like this, and there is no "Early termination of simulation", the autoshutoff criteria are satisfied.”, How should I make the next adjustment?
October 15, 2024 at 7:36 pm
Guilin Sun
Ansys EmployeePlease further increase the simulation time to 100 times longer.
5824
