Quesiton about periodic heat cycle by loading external heating load
    • lzfneu
      I want to consult you that I load three different external data (heat generate rate) and periodically endure a period of time, indicating three different heat loads in three different positions vs. time. I want to do such a periodic heat cycle among the three heat loads until the temperature to the steady state.
      I have no idea if there is a convenient method to do such a transient calculation so that I don't need to fill in the below blue blank from "0:heat generation1" to "2:heat generation1" again and again. Thanks in advance.
    • ErKo
      Hi
      Can you do all the rows and columns in excel since you have regular times and so on.
      Then paste that excel data into data view for the imported hat generation.
      Hope this might be of help.
      All the best
      Erik
    • lzfneu
      Dear Erik Thank you very much for your reply. It is very helpful suggestions, thank you again.
  • The topic ‘Quesiton about periodic heat cycle by loading external heating load’ is closed to new replies.
