February 21, 2024 at 8:48 pm
Amiiiiho
SubscriberHello
I want to simulate quantum dot photodector, but i dont know how i can define quantum dots in lumerical FDTD !
Does lumerical consider the sphere with 5 nm radius as quantum dot ? Or some special setting should be down for defining quantum dot ?
Please help me. Thank you
February 22, 2024 at 6:06 pm
Guilin Sun
Ansys EmployeeIn FDTD, the material (and the geometric shape) determines the physics of the device.
Thus Lumericla FDTD does not specify the diameter as quantum dot. Depending on your device and simulation goal, you may use dipole, or small sphere to represent the "quantum dot".
Please refer:
Quantum dot laser using 4-level 2-electron material
Greens function and local density of states of a dipole source
February 23, 2024 at 4:27 pm
Amiiiiho
SubscriberThank you for your help and reply????????.
Yes i mean is if i use a small sphere, will lumerical consider it as quantum dot?
My device is photodector and i use plane wave source as optical source and i want to optimize tha absorption by using quantum dot.
February 23, 2024 at 4:41 pm
Guilin Sun
Ansys EmployeeAs replied before, Lumerical FDTD does not have a quantum dot object. However as long you believe such a small sphere can represent it, with proper material property, FDTD can simulate it without any issue, provided that it can be well resolved, and its material property can describe the physics.
You use a plane wave for a single quantum dot with PML BCs? if there is only one, isolated quantum dot without periodicity, please use TFSF source. Plane wave source will be truncated by PML and will have diffraction.
https://optics.ansys.com/hc/en-us/articles/360034382874-Understanding-field-truncation-issues-with-finite-sized-plane-wave-sources
https://optics.ansys.com/hc/en-us/articles/360034382934-Tips-and-best-practices-when-using-the-FDTD-TFSF-source
https://optics.ansys.com/hc/en-us/articles/360034902133-Understanding-source-normalization-in-the-TFSF-source
February 24, 2024 at 7:10 am
Amiiiiho
SubscriberI have array of quantum dots, but i define one quantum dot with periodicity. In this situation, which soure is correct ?
And also i have another question: is it possible to see quantized bandstructure in lumerical ? And is it possible to see wave function diagram in lumerical ?
I mean i want to be assued that when i define a small sphere in lumerical, the lumerical consider it as quantum dot.
- The topic ‘Quantum dot photodector’ is closed to new replies.
5664
1890
1419
1304
