May 30, 2018 at 5:57 pm
knnn
Subscriberwhen I run a transient simulation in ANSYS maxwell, I get a final error saying "quality of mesh is not acceptable for this solution" no matter how small I make the mesh. How do I fix this issue?
June 12, 2018 at 6:18 pm
Mark Solveson
Ansys EmployeeTry changing to either Classic or TAU mesh in the Initial Mesh Settings. Â
Delete mesh operations to see if this is over-constraining the mesh to the geometry. Â
June 18, 2018 at 6:24 pm
knnn
SubscriberI have done that it does not change anything, but thank you for the suggestion
- The topic ‘Quality mesh’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
