April 8, 2024 at 7:13 am
jsan
SubscriberMeshing workflow — PyFluent (pyansys.com)Â
"I'm following this example. There are two ways to mesh in pyfluent, the new and old versions.
 The old version works fine,
but in the new version, the command 'watertight.create_surface_mesh.cfd_surface_mesh_controls.max_size.set_state(0.3)' isn't working
I'm using 24r1,
and commands like 'watertight.create_surface_mesh()' are working fine.Â
I'd like to check the new meshing workflow library.
I'm unable to proceed because I don't know the commands. I would be grateful if someone could help me out.
thx you.
April 10, 2024 at 12:00 pm
V.P
Ansys EmployeeHi Jisu,
I would recommend you to go through PyFluent examples listed here: Examples — PyFluent (pyansys.com)
They will give you a general idea on how to debug a command.
Also please check out this course on PyFluent: Getting Started with PyFluent | Ansys Innovation Courses
This course will help you to understand the basics and also help you get started.
- The topic ‘pyfluent ‘new meshing workflow’ example does not works’ is closed to new replies.
5969
1307
