January 9, 2024 at 2:46 pm
Zara Hamilton
SubscriberHi Trying to use the Geometry module but it say sits not compatable.
CodeÂ
from skimage import io, exposure, filters, measure, morphologyfrom skimage.measure import marching_cubesimport matplotlib.pyplot as pltimport numpy as np#import pyansysimport pyvista as pvfrom ansys.mapdl.core import launch_mapdlfrom ansys.geometry.core import launch_modeler_with_spaceclaim# File path to the image stackfile_path = 'myfilepath'# Load the images stackimages = io.imread(file_path)# Preprocess and segmentÂimages_eq = [exposure.equalize_hist(img) for img in images]thresholded_images = [img > filters.threshold_otsu(img) for img in images_eq]cleaned_images = [morphology.remove_small_objects(img, min_size=50) for img in thresholded_images]modoler_discovery= launch_modeler_with_spaceclaim()Â------------------------------------------------------------------------------------------------------------------------------------------------ErrorÂCRITICAL - Â - Â logger - handle_exception - Uncaught exception
Traceback (most recent call last):
 File "File_being_ran", line 24, in
 File "C:\Users\Users\miniconda3\Lib\site-packages\ansys\geometry\core\connection\launcher.py", line 566, in launch_modeler_with_spaceclaim  Â
  return prepare_and_start_backend(
 File "C:\Users\Users\miniconda3\Lib\site-packages\ansys\geometry\core\connection\product_instance.py", line 236, in prepare_and_start_backend
  _check_minimal_versions(product_version)
 File "C:\Users\Users\miniconda3\Lib\site-packages\ansys\geometry\core\connection\product_instance.py", line 373, in _check_minimal_versions Â
  raise SystemError(msg)
SystemError: PyAnsys Geometry is compatible with Ansys Products from version 23.2.1. Please install Ansys products 23.2.1 or later.--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------I have the latest version of ansys -
January 10, 2024 at 8:06 pm
mrife
Ansys EmployeeHi ZaraÂ
Support for PyAnsys 'products' are normally done via their GitHub pages. Please ask this here and be prepared with proof of version and also what license is being used to run SCDM. Â
https://github.com/ansys/pyansys-geometry/discussions
You should/could also use Pip to get the package information for the Python install and include that (to show the version of PyAnsys Geometry installed etc).
Mike
January 11, 2024 at 10:12 am
Zara Hamilton
SubscriberÂ
Thank you, I have posted there…. I think this might be license issue? do you know if there are limitations of student license through pyansys?
- The topic ‘PyANSYS Geometry’ is closed to new replies.
5939
1307
