November 18, 2021 at 6:16 am
sai
Subscriber? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsNeed help how to keep surface along the guide with offset to different location -
November 18, 2021 at 6:35 am
Devendra Badgujar
Forum ModeratorHi sai
I will look into this and get back to you soon.
November 18, 2021 at 8:20 am
Devendra Badgujar
Please can you share the model file so that I can check the behavior on it for better understanding.
Regards.
November 18, 2021 at 3:48 pm
sai
SubscriberDevendra BadgujarÂ
How do you want the model to be send
November 18, 2021 at 3:56 pm
Devendra Badgujar
Forum ModeratorsaiÂ
I have sent you the secure transfer link, please send your file through that.
Regards.
November 19, 2021 at 5:30 am
Devendra Badgujar
I have received the file , will check and get back to you soon.
November 19, 2021 at 6:40 am
Devendra Badgujar
To keep surface along the guide with offset to different location you can use Blend tool and selecting guide curves option to influence the blend. Please can you try and check if this works for you.
Let me know if you any further questions on it.
November 19, 2021 at 2:51 pm
Devendra Badgujar
Forum Moderator saiÂ
Also there are lot of geometry errors in your model may be that could be causing that issue for you.
- The topic ‘Pull Sweep offset’ is closed to new replies.
6189
