Electronics
Electronics
Properly simulating a ferrite bead in HFSS
    • peter.kirby
      HI Folks-
      I am looking to properly simulate a ferrite bead as a choke for a coax feed into an antenna. Specifically I am looking for some detailed help in translating the data sheet of a ferrite bead (amidon, ferrocube, etc) into the material properties in HFSS.
      Thank you for your time and help.
    • Praneeth
      Bbp_moderator
      You can create project variable for the material properties and you can define equations to implement the data set.
      You can also use dataset format for your purpose. Please go through "Working with Datasets" section of the HFSS help document.
      All the very best Praneeth.
  • The topic ‘Properly simulating a ferrite bead in HFSS’ is closed to new replies.
