Properly establihsing Boundary Conditions
    • nhatey
      Hello! I am trying to model a simple box with 2 inlets and 1 outlet. The fluid is air. The system is driven by the one outlet pushing air OUT of the system, and the 2 inlets pulling air in from the atmosphere. I am analyzing the system under transient conditions.
      How would I go about modeling the boundary conditions for this?
      I currently have the outlet as "mass-flow-outlet" and the 2 inlets as "inlet-vent". Multiple phases are turned off. Dynamic mesh with implicit updates are turned on.
      I keep getting the point float error although my model has good enough skewness and orthogonal quality. Am I having a mesh issue? Or is it an issue with initial conditions?
      I'd use a velocity boundary with a negative component/value and two pressure inlets. Vent is intended for something else (read the User's Guide) as I can't remember the definitions.
      Floating point could be mesh or boundary condition related. Just because the cells are good doesn't mean the mesh is: you may not have resolved the flow features sufficiently.
  • The topic ‘Properly establihsing Boundary Conditions’ is closed to new replies.
