Propeller blade meshing
    • Deep Nath
      I am trying to develop structured mesh in propeller blade but unable to develop. in workbench I tried, but unstructred gives me a validted result but the y+ value is very high. Now, I need structured mesh, and I tried with icem surface mesh but still that smooth curves are not generating. Seeking your help in this direction.
      If y+ is high what boundary layer settings did you use?
      ICEM CFD is not a simple code to use, and using the blocking part is fairly advanced.
      • Deep Nath
        Thanks Rob,
        Actually I started developing mesh in ICEM and somehow I developed in ICEM, a structured mesh. But yes, it was bit tricky. But thanks for your reply.
    • C N
      Hello Deep,
      I recommend you to first take a cross section of the propellor blade so that you get a airfoil kind of geometry in design modeller and then create c mesh domain and then in ansys meshing through mapped face meshing and edge sizing create a conformal mesh . I have attached the AIC course link for your reference with detailed information.
      Mesh — Lesson 4 - ANSYS Innovation Courses
      I hope this solves your problem.
      Thanks,
      Chaitanya Natraj
      • Deep Nath
        Thanks CN,
        I have started develpoing mesh in ICEm and somehow it is coming a structured one. Still if I find more difficulties I'll look into design modeller. And thanks for sharing this video..yes, this option is a good one. I'll try it if needed.
        Thanks
        Nath
  • The topic ‘Propeller blade meshing’ is closed to new replies.
