May 4, 2024 at 8:24 am
Gregory Szuladzinski
Subscriber/BATCHÂ/PREP7/TITLE, RING STABILITYÂET,1,LINK180ET,2,63  !!! SHELL ELEMENTEX,2,72000. $NUXY,2,0.33 $DENS,2,0.0028R,2,2.0!LOCAL,11,1,0,0,0K,1,0,1900,0,K,2,0,1900,-20,K,4,0,1846,-20,K,5,0,1792,-20K,6,0,1792,0K,201,1900,0,0K,202,1900,0,-20K,301,1846,0,-20K,401,1792,0,-20K,501,1792,0,0R,1,2.0/TRIAD,LBOT! /DEV,FONT,ENTITY,MENUÂ/dev,font,2,Courier*New,700,0,-13,0,0,,,Â!!!!!!!!!!!!!!!!!!!!!!!!!!!ÂLOCAL,11,1,0,0,0CSYS,11LSTR,    1,    2 ÂLSTR,    2,    4ÂLSTR,4,5LSTR,5,6LSTR,201,202LSTR,301,202LSTR,401,501LSTR,301,401L,5,401L,6,501L,1,201L,2,202ÂL,4,301/PNUM,KP,1 Â/PNUM,LINE,1/PNUM,AREA,1!!!!!!!!!!!!!!!!!!!!!TYPE,2 $REAL,2 $MAT,2A,1,2,202,201 ÂA,2,4,301,202 ÂA,5,6,501,401 ÂA,4,5,401,301 ÂESIZE,10,0,FLST,5,4,5,ORDE,2 ÂFITEM,5,1 ÂFITEM,5,-4 ÂCM,_Y,AREA ÂASEL, , , ,P51XÂCM,_Y1,AREAÂCHKMSH,'AREA' ÂCMSEL,S,_Y Â!* ÂMSHKEY,1AMESH,_Y1 ÂMSHKEY,0!* ÂCMDELE,_Y ÂCMDELE,_Y1 ÂCMDELE,_Y2Â!!!!!!!!!!!!!!!!!!!!!!!!!!! ANOTHER REFLECTIONÂCSYSÂNSYM,Y,6000,ALLÂESYM,,6000,ALL ÂNUMMRG,NODE,1,1Â!!!!!!!!!!!!!  AGAIN A REFLECTIONÂNSYM,Z,12000,ALLESYM,,12000,ALLÂNUMMRG,NODE,1,1!!!!!!!!!!!!!!!!!!!! FINAL ONEÂNSYM,X,24000,ALLÂESYM,,24000,ALL ÂNUMMRG,NODE,1,1!!!!!!!!!!!!!!! FIXINGNSEL,S,LOC,Y,-5,5NSEL,R,LOC,X,1000,2500 Â/REP,FAST ÂD,ALL,ALLNALL!!! GRAVITY X10ACEL,0.0981!!!!!!!!!!!!!!!!! HORIZONTAL STRETCHFINI!/SOLU!SOLVEALLSÂ!!!!!!!!!!!!!!!!!!! ÂCSYS,11ÂNSEL,S,LOC,X,1895,1905ÂFINI/PREP7 ÂSF,ALL,PRES,1.00/PSF,PRES,,2!!!!!!!!!!!!!!!!!!!/SOLUANTYPE,BUCKLEBUCOPT,LANB,3M,ALL,ALLMXPAND,3OUTRES,BASIC,LASTThis is an input file that works well. However, when I add "solve", then the whole screen vanishes.
Gregory
May 6, 2024 at 10:36 am
Ashish Khemka
Forum ModeratorHi,
Can you check the .out file for solution progress? It may be happening because you are solving in batch mode. Please see if the following thread helps: Get Load Step Progress while doing APDL Batch run (ansys.com)
Ashish Khemka
- The topic ‘Program vanishing from screen’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1220
1118
1015
