October 27, 2025 at 5:44 pm
javat33489
SubscriberHello everyone. I'm solving an impact problem. A steel cylinder impacts a CNG plate.
When I calculate with MASSCALE D2TMS, everything works.
If I remove the mass scale, I get an error:   871 t 9.9996E-02 dt 1.15E-04 write d3plot file       10/27/25 17:51:10
  1741 t 1.9999E-01 dt 1.15E-04 write d3plot file       10/27/25 17:52:35
  2611 t 2.9999E-01 dt 1.15E-04 write d3plot file       10/27/25 17:54:15
  3705 t 3.9995E-01 dt 8.81E-05 write d3plot file       10/27/25 17:56:47
  4887 t 4.9998E-01 dt 6.33E-05 write d3plot file       10/27/25 17:59:39
  5000 t 5.0722E-01 dt 6.26E-05 flush i/o buffers       10/27/25 17:59:56
  7999 t 5.9999E-01 dt 1.69E-05 write d3plot file       10/27/25 18:07:35
  10000 t 6.1699E-01 dt 8.01E-06 flush i/o buffers       10/27/25 18:12:49
forrtl: severe (157): Program Exception - access violation
Image        PC         Routine       Line     Source
lsdyna_dp.exe    00007FF7DCBB0408  BKSRT4A         15470  fem3d_a.F
lsdyna_dp.exe    00007FF7E2CA3198  ASLAV0R         28402  dynpc.F
lsdyna_dp.exe    00007FF7DFA3C15A  CONTACT          2747  dyn33.F
lsdyna_dp.exe    00007FF7DCC0E4E0  FEM3D_CONTACT      39418  fem3d_a.F
lsdyna_dp.exe    00007FF7DCB4F840  FEM3D          12147  fem3d.F
lsdyna_dp.exe    00007FF7DCB42858  SOLTN           441  fem3d.F
lsdyna_dp.exe    00007FF7DCC7DC38  OVERLY           277  dyn0.F
lsdyna_dp.exe    00007FF7DB8047BF  LSDYNA1          965  dynm.F
lsdyna_dp.exe    00007FF7DB804129  MAIN__          2060  dynm.F
lsdyna_dp.exe    00007FF7E98BD3E2  Unknown        Unknown  Unknown
lsdyna_dp.exe    00007FF7EA1D0358  Unknown        Unknown  Unknown
KERNEL32.DLL    00007FF8EED8E8D7  Unknown        Unknown  Unknown
ntdll.dll      00007FF8EF6AC53C  Unknown        Unknown  UnknownWhy?
Thanks. -
October 28, 2025 at 7:49 am
ErKo
Ansys EmployeeÂ
Hi
As you use often large models and realistic geometries you have likely a commercial licence. It is also impossible to say what the above error is caused by with out looking at the model – please send the licence number or TECS nr, together with a NON export controlled model, via a support ticket (ACCS system), or if you are supported by a channel partner in your region, so we can help you with this issue.
All the best
Erik
October 31, 2025 at 12:02 pm
ErKo
Ansys EmployeeHi
Just wanted to check if you send your model to our support or your channel partner, and if so was it resolved?
Thank youErik
4507
1494
1386
1209
