April 1, 2022 at 3:16 pm
vlehmann
SubscriberHi All,
I am trying to run an single frequency HFSS simulation on an HPC and get the error "process hf3d exited with code 149". Does anyone know what the error means or where I can find out how to fix it? I was able to run this simulation on a local server without issue.
Thank you,
Valerie
April 12, 2022 at 11:29 amPraneeth
We need more information on this to serve you better.
There can be multiple reasons for this error.
Please check below points and take action accordingly.
At what stage of simulation this error is triggered - like adaptive meshing stage, frequency sweep?
Are you running manual HPC setup or the automatic? If you are using manual then try automatic once.
Does your HPC machine has enough RAM?
All the very best Praneeth.
April 12, 2022 at 6:24 pmvlehmann
SubscriberHello Praneeth The error is triggered right after "Adaptive Pass #1 - Solving single frequency for adaptive meshing". The full error says that "Design:HFSSDesign1 (DrivenModal), Solving adaptive frequency ... (Domain solver), process hf3d exited with code 149."
The HPC is automatic I believe. How would I be able to tell if I have enough RAM? I didn't see an error about the RAM.
Thank you Valerie
January 17, 2023 at 9:59 pmparhamz
SubscriberHello all,
How did you solve this problem ? I have Ansys electronics desktop 2022 R2 working on ubuntu 20.04 . I made my mesh pretty coarse and I have a lot of RAM and CPU power on my local machine and I still get this error. No matter I use direct solver or iterative solver I get the same issue. What is the solution for this problem ?Here is the detail of the error that I get:
C_to_Sq_transition (/mnt/DD/ansys_electronics_projects/project_test/)
Transition_wr75 (Modal Network)
[error] Solving frequencies ... (Nondomain solver), process hf3d exited with code 149. (1:55:20 PM Jan 17, 2023)
[info] A discrete frequency sweep with 17 point(s) has been started using HFSS - Solving Distributed. (1:55:42 PM Jan 17, 2023)
[info] Discrete frequency sweep complete. (1:55:42 PM Jan 17, 2023)
[error] Sweep first_analysis_sweep_coarse failed (1:55:42 PM Jan 17, 2023)
[error] Simulation completed with execution error on server: Local Machine. (1:55:42 PM Jan 17, 2023)October 12, 2023 at 9:57 amSuhrith Bellamkonda
SubscriberI'm getting this error: process hf3d exited with code -1073741795, after I run "analyze". Any tips on how to resolve this?
Viewing 4 reply threads- The topic ‘“process hf3d exited with code 149” on HPC’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4007
1461
1287
1124
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
