January 27, 2020 at 9:22 pm
ansysuser2020
SubscriberÂ
I prerare my fluent case, than have some solutions with results. After returning to the case thru the time can not initialization with this error. Â
Can anybody help?Â
Node 0: Process 10300: Received signal SIGSEGV.
Node 1:
Process 8132: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
January 28, 2020 at 5:55 am
Amine Ben Hadj Ali
Ansys EmployeeWhat does it happen with standard initialization? What do you mean with return thru the time? -
January 28, 2020 at 6:02 am
ansysuser2020
SubscriberI mean, my project working before.
after restar I have this error Â
January 28, 2020 at 11:16 am
Amine Ben Hadj Ali
Ansys EmployeeTest on other machine, on different number of CPU's and the first test is to test with another initialization.
January 28, 2020 at 4:01 pm
ansysuser2020
nothing
January 28, 2020 at 4:20 pm
Forum ModeratorNothing = no error? Or standard initialisation didn't work either?
January 28, 2020 at 4:24 pm
ansysuser2020
January 28, 2020 at 5:05 pm
Amine Ben Hadj Ali
Ansys EmployeeStrange: sure it worked before? Recreate the case from mesh. -
January 29, 2020 at 6:41 am
ansysuser2020
SubscriberStrange: sure it worked before? Recreate the case from mesh.
yes I am sure.Â
mesh was creat in ICEM and ANSYS mesher. It nonrotating air domain and rotating. Use periodic interface. Inlet - velocity , outlet - pressure Â
January 29, 2020 at 6:46 am
Amine Ben Hadj Ali
Ansys EmployeeOkay then it is another argument to do the setup from scratch.
- The topic ‘Process 8132: Received signal SIGSEGV.’ is closed to new replies.
 - affinity not set
                        4167
                        1487
                        1363
                        1194
