TAGGED: -Ansys-Maxwell-electronics, ansys-circuit, ECE-model
January 21, 2024 at 1:55 pm
Zhengting.Wu
SubscriberHi there,
I tried to use ERE3 and ECER Model to make a current and angle sweep analysis for my 3-Phase,12Poles PMSM Motor.
I want to have a current sweep between 0A and 400A, an angle sweep between 0deg and 10deg.
And the results came out strange.
-for current: I thought I would get a current Interval [-400A,400A], with 100A as a step.Â
-for Angel: I thought I would get an angle Interval [0deg,10deg] with 5 steps.
As you can see, the results are not what I have set.Â
What I try to do is the same in this link:https://www.mathworks.com/content/dam/mathworks/mathworks-dot-com/solutions/automotive/files/mac2017/deriving-fast-accurate-pmsm-motor-model-from-finite-element-analysis.pdfÂ
There are some examples of settings on page 26 so I did the same. But the results came differently.
Wu
January 24, 2024 at 9:17 pm
HDLI
Ansys EmployeeHello Zhengting,
   For the circuit, please deactivate coils and delete current sources, so we need 3 deactivated coils for 3 phase winding, ECE3, ECER and ground.Â
   Please reviewe the tutorial in ALH if possible, https://jam8.sapjam.com/groups/NA4AXmq6h4aU43Ap36G0uU/documents/slMdBzf6vnLU0adOCR02h2/slide_viewer
   Similar circuit in,  ECE for SR motor
   Thanks.
HDLI
- The topic ‘problems with the Model ECE and ECER’ is closed to new replies.
