December 18, 2023 at 7:51 pm
calvinmooney03
SubscriberHi everyone, I am trying to model a transmission tower and when i go to solve for my results i get the following errors:
"A solver pivot warning or error has been detected in the ROTZ degree of freedom of node 129008 located in SYS-2\Beam (Extracted Profile1). This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Â Check results carefully. You may select the offending object and/or geometry via RMB on this warning in the Messages window."
"Solver pivot warnings or errors have been encountered during the solution. Â This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Â Check results carefully."
What might i be able to do to fix this, I have tried sharing the topologoy of the structure in spaceclaim but that makes my model disappear completely in mechancial. I have also tried changing "beam cross section (for solver)" from pre-integrated to mesh. And changed the "Beam section results" to Yes.
December 20, 2023 at 10:48 am
Ashish Khemka
Forum ModeratorHi,
Try performing a modal analysis to see the deformation of the model. Unconstrained DOF will give you zero frequency and will help to identify unconstrained parts.
Ashish Khemka
January 4, 2024 at 4:18 pm
calvinmooney03
SubscriberHi, I am now just getting the errorÂ
I have looked at other answers on the forum and cannot seem to get a solution, what can i do to fix this?
I attached a download for an archive of the project in a reply below this if you want to have a look.
Thanks.
December 26, 2023 at 1:33 pm
joseronaldo.15
SubscriberHi, you can share the proyect?
January 4, 2024 at 3:53 pm
calvinmooney03
Subscriberhttps://atlantictu-my.sharepoint.com/:u:/r/personal/g00391348_atu_ie/Documents/Year%204/Major%20Project/Third%20Transmission%20Tower%20Design.wbpz?csf=1&web=1&e=EUZp6c
This is the link to download the file; let me know if you can access it. The project I’m working on is in static structural C. Thanks.
January 8, 2024 at 10:46 pm
joseronaldo.15
SubscriberI can not download
- The topic ‘Problems with generating static structural solutions’ is closed to new replies.
5639
1885
1403
1303
