Problems with FSI Postprocessing
    • atiwari
      Hello everyone,
      I am trying to solve the FSI problem in workbench (transient + fluent) based on the ANSYS How to Tutorial on ANSYS Workbench 2021R1. The link to the tutorial is attached below.
      https://www.youtube.com/watch?v=oOGkvrnKS-c
      I have managed to solve the full fsi problem without any errors but i am facing problems in the post-processing part as shown in figure below
      As told in tutorial it is said to connect solution of transient structural .i.e. B6 to results of fluent i.e. C6. But when i try to connect the workbench is not connecting it showing the denied    sign. Can i anyone help me figure out the way or tell me what i am doing wrong with this setup.
      Thanks in Advance.
      Abhinav
    • Nikhil N
      Hello Abhinav,
      Just a thought. Can you drag a standalone 'Results' component system into the project schematic and try connecting solutions of both the Transient structural and Fluent to the results?
      • atiwari
        Hello Nikhil,
        Thank you for the quick reply.
        I tried with the stand alone results. I was able to connect the solution of the fluent but for transient i am still facing the same issue. Please find the attached picture below for you reference.
        Thanks for you help.
        Best Regards,
        Abhinav
        • Rahul
          Hello Abhinav,
          You can view the coupled analysis results in Ensight.
          To view coupled results in EnSight you you have to follow the procedure as. (/forum/wp-content/uploads/forum-uploads/149/HUBQN99F4L5X.pdf)
          1. Load System Coupling results. For the Look in field, navigate to System Coupling's results folder, \dp0\SC\SC\SyC\Results
          2. Load Mechanical results.
                      > File > Open > Enable keep Currently Loaded data >  (load .rst file from \dp0\FFF\MECH) Enable advanced interface > Load all parts
              3. Load Fluent Results
                     > File > Open > Enable keep Currently Loaded data > (load .rst file from \dp0\FFF\Fluent) Enable advanced interface > Select .cas file
                      Edit both file names, replacing the step number with a wild card, as follows:
                              \dp0\FFF\Fluent\FFF.1-1-*.cas.h5
                              \dp0\FFF\Fluent\FFF.1-1-*.dat.h5           and load all parts.
          Hope that helps!!
          Rahul
    • Stephen Orlando
      Loading Mechanical results in CFD-Post is no longer supported as of 2021R1. This is mentioned here: 3.3. Incompatibilities (ansys.com)
  • The topic ‘Problems with FSI Postprocessing’ is closed to new replies.
