August 22, 2017 at 8:38 pm
anajib
SubscriberI am modeling a helical pipe encased in a solid medium (backfill). The medium is surrounded by soil. The pipe has water inside.
I created a hollow pipe and then imported it to Ansys (SpaceClaim). I then created a cylinder surrounding this pipe and used the merge command to get a cylindrical backfill around this pipe and water (body inside the helical pipe). The backfill is surrounded by cylindrical region of soil.
When I import the model for meshing, multiple contacts are automatically generated. Most of these have unequal number of target to contact faces e.g. Contact 2 has 6 contact faces and 8 target faces. In addition they form overlapping contacts that need to be repaired.
I wanted to avoid these so I decreased the tolerance value of the auto detection in details of contact. I then get lesser contacts but some still need to repair and suppress some.
Once I repair them and import the Mesh to Fluent I get this error message:
Warning: zone of type interior found between different solids!
Material of cell zone 7 is bckfill, while material of cell zone 8 is hdpe.
Material of cell zone 7 is bckfill, while material of cell zone 6 is soil.
This will adversely affect the solution.
It is recommended that you fix this issue via the TUI command
August 30, 2017 at 11:19 am
Holger Grotjans
Ansys EmployeeYou can use "Share Topology" in SpaceClaim to get the contacts right in the Geometry already.
- The topic ‘Problems with connections/contacts while meshing in Ansys:’ is closed to new replies.
6855
1343
1152
