TAGGED: mesh-generation, solidworks, solution-problems
February 8, 2021 at 3:01 pm
Wazawaki
SubscriberHello,
I've designed a red blood cell in Solidworks and now imported it to Ansys. But having trouble meshing it I'm new to this software so I'm a bit lost, any help with be greatly appreciated. The design is attached below, thank you.
February 9, 2021 at 5:11 amKeyur Kanade
Ansys EmployeeThis is very generic error. This could be due to geometry problem or due to wrong mesh sizing. Can you please check following? nPlease check geometry in SpaceClaim. Select geometry in structure tree --> Use right click --> Select Check Geometry. The geometry should be error free to proceed. If geometry has any errors, please modify/recreate geometry at those places.nIf geometry is error free, then please select appropreiate Physics Preference in meshing. nPlease give body/face/edge sizing so that mesh has sufficient mesh density and resolve important features. nFor the error, please use right click on the error and click on 'problematic geometry'. This will highlight geometry which is failing to mesh. You will need to modify geometry at this location or change mesh sizing. nIf your meshing has special controls like periodicity, please check if those are correctly defined. nAlso you need to define sizing correctly. Please go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- The topic ‘Problems meshing my Solidworks design’ is closed to new replies.
3572
1188
1076
1063
952
