July 7, 2019 at 4:17 pm
diegorod
SubscriberHello everyone. I'm stuck in the middle of a problem with Ansys Meshing. The thing is that I'm trying to mesh a 90 degree pipe bend (3D)Â and I get problems when introducing inflation. As you all can see, close to the bend I get no problems without inflation, but introducing this option I get a transversal "distorsion" (The lines perpendicular to the flow direction are not parallel) Thank you
July 7, 2019 at 4:18 pm
July 7, 2019 at 4:19 pm
July 7, 2019 at 6:22 pm
peteroznewman
SubscriberGo into DesignModeler, create two planes and slice the solid body into three pieces, the two straight pipes and the elbow. Select the three pieces and Form New Part to make a multi-body part that will have mesh connectivity. Then apply the inflation and the elements on the bottom can easily be made with no skewness.
July 8, 2019 at 10:19 am
July 8, 2019 at 10:21 am
diegorod
SubscriberThe error says "the meshing has completed, but some elements are not compliant with the applied shape checking criteria"
July 8, 2019 at 10:48 am
peteroznewman
SubscriberDelete the Multizone mesh method and the Inflation mesh controls you have.
Under Mesh insert a Mesh Control Method and set the type to Sweep. Select just one straight pipe for the body. On the Source face, select a circular end face.
Now RMB on the Sweep mesh control and select Inflate this Method. It will automatically light up the end face that is the source. Now select the circular edge.
Generate Mesh. I think the Multi-body part will carry that sweep to the other two bodies without applying any mesh control to them. Try that first. If it doesn't work, you can repeat the mesh control on the other two bodies.
July 8, 2019 at 11:01 am
diegorod
SubscriberThe sweep method doesn't let me select a face boundary when inflating the method
July 8, 2019 at 2:15 pm
peteroznewman
SubscriberYou don't select a face for the boundary, you select the circular edge. The object you are applying the inflation to is the end face of the cylindrical solid. It will sweep the 2D mesh on the end face along the pipe.
July 8, 2019 at 3:49 pm
July 8, 2019 at 5:28 pm
peteroznewman
SubscriberLooking at the big circles around your cursor, your default element size is about 100 times too large. Try again with different settings under Mesh Details.
July 8, 2019 at 8:17 pm
- The topic ‘Problems in the meshing module when using inflation’ is closed to new replies.
5779
