August 1, 2022 at 1:58 pm
Junwu Bai
SubscriberI tried to simulate the thermal transportation in a photodiode. And AlN or diamond is attached to Au tried to get better thermal transport. I only set T=300K as the boundary condition at the bottom of simulation region. But after the simulation, I found T profile shows no difference w AlN and wo AlN. Is there anythinig or boundary condition I forgot to set? Thanks for your guys help.
August 2, 2022 at 11:23 pm
Guilin Sun
Ansys EmployeeIt can be due to different reasons.
What is the AIN and are its thermal parameters correct?
It seems the T=300k boundary is too close to the source, which drains the heat to room temperature. Why do you simulate larger AIN space but not the substrate T=300k?
- The topic ‘Problems in Heat simulation’ is closed to new replies.
