March 14, 2024 at 3:41 pm
云川 王
SubscriberHello everyone, I encountered some problems when I used LS-DYNA module in ANSYS WB to do drop simulation analysis. I obtained the stress-strain curve of EPE material through uniaxial compression test, and created EPE material in the engineering database to input the test data and used second-order Ogden constitutive to fit the material as shown in the figure. When I solve in the LS-DYNA module when the system reported an error, I do not know how to solve, hope to have the big guy advice, thank you (I found that the Ogden model I defined worked fine in "Static structal", but there were errors in LS-DYNA)
March 14, 2024 at 3:48 pm
March 14, 2024 at 3:50 pm
云川 王
SubscriberI need some help,thanks
March 14, 2024 at 4:10 pm
ErKo
Ansys EmployeeHi
I suggest to post this in the LS-Dyna forum.
Thank you
Erik
- The topic ‘Problem:Ogden in LS-DYNA’ is closed to new replies.
5814
