January 14, 2021 at 9:41 am
Aminaa
Subscriberhi, every one nMy problem is a two-dimensional double diffusion problemin square cavity. there is a temperature difference and a concentration difference between vertical walls, and the horizontal wall is adiabatic and impermeable.ni tried to simulate my problem:n- i checked the report flux for the total mass rate i`am surprised because it displayed zero on vertical walls while i imposed mass fraction !!!ni calculated the sherwood number for the right and left walls and i didn`t had a conservationnfor the mixture i used(air+h2o vapor) with imposed physical propertiesnthanksn -
January 14, 2021 at 10:57 am
DrAmine
Ansys Employee1/Where did you check that mass rate report?n2/What do you want to do? Add some screenshots of your case and model/bc settings.n -
January 14, 2021 at 11:21 am
Aminaa
nthnak you Dr Amine for anwsering,nthe cavity is failed with a mixture of air+13% H2O vapor. The horizontal walls are adiabatics and impermeables, the verticals ones have imposed temperatures and mass fractions.n Th: hot temperaturenYh: hight mass fraction of H2O vapornTc:cold temperaturenYc:low mass fraction of H2O vapor.nfor the mixture i imposed physical properties, with mass diffusivity coef.nnafter runing my case, i checked the conservation mass flux on vertical walls (by report) and it displayed me zero ni do the same thing with heat flux and it display the conservation!!! where is the problem
January 14, 2021 at 6:22 pm
YasserSelima
Subscriberis it mass flux of H2O, or mixture?n -
January 17, 2021 at 9:14 pm
Aminaa
Subscriberis it mass flux of H2O, or mixture?/forum/discussion/comment/103100#Comment_103100
hi,yasser selima thnaks for reply nit is a H2O fluxn -
January 17, 2021 at 9:58 pm
YasserSelima
SubscriberThis is strange!!nTry decreasing Yc and increasing Yh and see what get!nAlso plot contours of H2O volume fraction and see how it is distributed in the room. May be we can see somethingn -
January 18, 2021 at 9:28 am
DrAmine
Ansys EmployeeWhat do you want to do? To add Species through walls?n
Viewing 6 reply threads
- The topic ‘probleme with mass conservation’ is closed to new replies.
