November 19, 2019 at 6:37 pm
Sereno
SubscriberHy everybody!
I was just modeling a simple structure (a portal with 2 columns and 1 beam) and I associated to the element that I drew on SpaceClaims a Cross Section taken from Eurocode like an IPE profile. The problem is that when i run the solution in the Model Space the following message appears:
"One or more beams with user-defined mesh cross sections have been sent to the solver as pre-integrated sections. Beam section results will not be available for these bodies. If these results are desired, please change the Cross Section (For Solver) property for those bodies".
What does it mean? I don't get the results because of this reason. Can anyone help me to solve this problem and get the results, please?
Thank you so much in advance. -
November 19, 2019 at 7:03 pm
peteroznewman
SubscriberIf you look at the ANSYS help page for the Beam Tool, it includes this note:
Note: Note the following limitations for the Beam Tool:
The Beam Tool does not support bending or combined stress results when scoped to a geometry that:
Includes a user-defined cross-section.
Originated from the SpaceClaim Eurocode Library.
I think the workaround is to not use the SpaceClaim Eurocode Library. Use instead the Profile tool in SpaceClaim.
If they are I beam columns, then add an I beam and edit it to the dimensions you need.
November 19, 2019 at 8:57 pm
Sereno
SubscriberOk I'll follow your suggestion and then I run the solution to see if it works. Thank you for your help -
November 20, 2019 at 7:12 am
Rohith Patchigolla
Ansys EmployeeHello Sereno
When you create a beam with a custom-section in Spaceclaim , you will have “Cross Section (For Solver)” option in Mechanical in the details of the line body.
Please try setting this to “Mesh” and solve again.
Best regards Rohith -
December 19, 2019 at 9:35 pm
shehabi
SubscriberHello Rgpatch,
I have the same Problem here, and I'm happy to know that there's been a solution for it. Could you provide a screenshot where is this “Cross Section (for Solver)” option?
Thanks.
December 20, 2019 at 10:19 am
June 22, 2020 at 6:13 am
AmbarNaik13
SubscriberHi Rohit,
I have faced a similar problem. There is a warning; Please set the beam section results to Yes to display stresses in the beam elements. I tried to implement the solution you provided however, there is no option of cross-section (for solver) in ANSYS 2019 R2. Could you please give me any idea how it could be implemented here?
June 22, 2020 at 6:59 am
July 9, 2020 at 8:40 am
munkhunur
SubscriberIt is working. Brilliant. Thanks buddy.
March 6, 2021 at 10:09 am
deepakchandan
SubscriberWell after going through the overall pst of the members which clearly stats that the knowledge shared here is very vast and commendable. however, the information of ASTM A36 IPE BEAM can be gained at Ranflex Metals.n
- The topic ‘Problem with Structrural Analysis solution’ is closed to new replies.
3190
1024
962
859
798
