May 14, 2024 at 12:21 pm
losinyao181031
SubscriberHello, everyone.
I am currently using forte for a dual fuel engine in-cylinder combustion simulation and I need to use the tool to make a sector. but at the time I got a graph after entering the piston bowl and engine parameters. The graphic shows that the inside of the cylinder and the piston bowl are not in the same plane. I have tried all versions of ANSYS from 2022 to 2024, including the student version, and the same problem occurs, how can I solve it? -
May 21, 2024 at 3:33 pm
SVV
Ansys EmployeeHi,
Looks like the profile input was given in reverse order. Can you please revisit your inputs.
- The topic ‘Problem with sector generation’ is closed to new replies.
