July 11, 2023 at 4:23 pm
Matteo Montemurro
SubscriberI want to do an impact simulation in ANSYS using Explicit Dynamics. When I remotely attached a point mass to the body surface, I encountered with an error: "Deformable behavior for remote entities is not supported in Explicit Dynamics systems. Please change such behavior to Rigid". But when i changed the point mass behavior to Rigid, another error occurred: "Could not transfer loads and constraints to the solver". What is wrong here? How do i do a simulation in Explicit Dynamics with a remotely attached point mass to body surface. Thanks in advance!
July 13, 2023 at 1:40 pm
Ram Gopisetti
Ansys EmployeeHiÂ
usually,Remote Point does not have Rigid behavior and it will be ignored by the Explicit solver during the analysis.
but point mass can be either applided to the remote points and it should solves correctly , check your setup againÂ
both point mass and remote point being deformableÂ
both point mass and remote point being rigid
cheers, ramÂ
- The topic ‘Problem with point mass in Ansys Explicit Dynamics’ is closed to new replies.
4597
1495
1386
1209
