June 4, 2018 at 8:21 pm
Tahywo
SubscriberHi,
I am trying to check for the temperature distribution of tubes in a cylindrical shaped thermal shield. Because of the complexity of the geometry, I am presently looking at the two tubes at the base plate. I am having an issue with the mesh interface at the setup, also it was showing an error (Error: 0nquire-adjacent-threads: not a face thread - Error Object: #) after opening set up.
Anyone experienced something similar or with an idea on how to go about this? your help will be highly appreciated.
June 5, 2018 at 1:49 pm
raul.raghav
SubscriberCould you attach your workbench archive file so we could take a look into it? If you're not sure how to create and share a workbench archive file, please refer: Saving & sharing of Working project files in .wbpz format
June 5, 2018 at 2:32 pm
Tahywo
SubscriberThank you Raul.
Please find attached.
June 5, 2018 at 7:59 pm
June 6, 2018 at 11:21 am
Vishal Ganore
Ansys EmployeeYou have bodies in surface contact with each other. Please use shared topology option as shown below:
https://www.youtube.com/watch?v=h43E1YO1LiM&t=83s
You also need to work on meshing each part. Apply suitable mesh type and size to achieve good mesh. Default mesh option will not produce good mesh for your application.
June 6, 2018 at 5:44 pm
Tahywo
SubscriberThank you Vishal. Will try this out.
- The topic ‘Problem with Mesh Interface in Setup’ is closed to new replies.
5094
1830
1387
1248
