TAGGED: ansys-mechanical, mechanical, transient-structural
July 11, 2023 at 12:14 pm
Germán Ferrando
SubscriberHello,
I am quite new in Ansys, I am modelling in transient structural a mechanism to see the required N.m I need in my motors to move this system.
The system consist of two main links, the first one that we see in this picture has inside a stick with a cylindrical joint and at the end of the stick there is a circular body which has a spherical joint with the ball. This ball has a cylindrical joint with respect to another stick that is connected to the big part.
The other link is another revolute joint to the ground connected with the big green part with a small solid that has rotation with the linked rotated respect to the ground and with the green big part.
When i execute a known movement of the mechanism this happens, the body linked with spherical joint goes out of the line.
I can give you the model if it is more clarifying, i have thought about contacts but none seem to work.
July 11, 2023 at 7:30 pm
peteroznewman
SubscriberThe spherical joint is providing 3 rotational degrees of freedom. The ball should slide along the rod with a Translational joint, not a Cylindrical joint since the spherical joint already has rotational freedom and the cylindrical joint freedom about the rod axis is redundant.
If you need more help, in Workbench, use File, Archive and put the *.wbpz file on your Google Drive and put the link that anyone can open into your reply.
July 13, 2023 at 7:45 am
Germán Ferrando
SubscriberHi Peter, thanks for your answer, i tried but it happened the same issue, i also tried replacing the revolute joint with a bearing but then it doesnt keep contact with the big part. I have surpressed all the parts that arent the mechanism and the right transient structural is the one named final project.
https://drive.google.com/file/d/1lAOetEZLWw3OQzT7ECEIbwumt4ykUkOa/view?usp=drive_link
July 13, 2023 at 1:03 pm
July 13, 2023 at 1:40 pm
Germán Ferrando
SubscriberSorry Peter, the access was restricted i think you can now. Thanks.
https://drive.google.com/file/d/1lAOetEZLWw3OQzT7ECEIbwumt4ykUkOa/view?usp=sharing
July 15, 2023 at 2:10 pm
July 20, 2023 at 7:09 am
Germán Ferrando
SubscriberThanks Peter!!
- The topic ‘Problem with mechanism, spherical joint out of the body’ is closed to new replies.
5704
1891
1419
