Problem with mass matrix – APDL
    • Diona Çejku
      Hello everyone,
      I've been working on extracting mass matrices from Ansys APDL using the following code for analysis:
      ANTYPE,MODAL
      MODOP,LANB,10
      /STATUS,SOLU
      /SOLU
      OUTPR,BASIC,1
      /OUT,SCRATCH
      SOLVE
      /POST1
      SET,FIRST
      *dmat, m0, D, import, full, file.full, mass
      *print, m0, matm.txt   ! Exports Mass to Text File
      *export, m0, mmf, matmMMF.txt ! Exports Mass as MMF
      /OUT
      FINISH
      However, I've encountered an issue where the extracted matrix is not diagonal. I've double-checked my code and inputs, but I'm still unable to identify the source of the problem. I would highly appreciate if anyone could help to resolve this issue.
    • mrife
      Hi Diona
      Why would the mass matrix be diagonal?  My guess is that you are assuming a lumped mass formulation...if so please see the help on the Mechanical APDL command LUMPM.  You may also want to read the MAPDL Theory Guide, chapter 12.5 (Element Reference -> Lumped Matrices) as there are some caveats to using this.
      Mike
  • The topic ‘Problem with mass matrix – APDL’ is closed to new replies.
